filling washer fluid
- patty
- Vehicle: delica chamonix
does any one have a trick to filling the front window washer fluid.its in a pretty weird location,im trying to find a funnle that can bend that much but its not lookin so good.in the summe ri just put a hose in it and filled with water but that wont do much good in the winter.
Re: filling washer fluid
I read that with a good tug it pulls out then slides back in
I would rather wear out then rust away.
- DelicaMark
- Vehicle: L400
Yep just pull it straight back towards the seat. There is a channel in the reservoir that slides along a bolt or something that is attached to the wall.
-Mark
-Mark
- patty
damn i feel dumb now,thanx
coaxial
it does?? damn now I can stop fighting with an awkward funnel every time I fill it. It took me a while just to find it :)
- patty
ok, am i suppose to really yard on it.does it pull out at the top on a angle,or does the thing slide out?
- DelicaMark
- Vehicle: L400
It should pull horizontially out towards the passenger seat. Pull it along the wall of that it is attached to. No angle. I'd say you need to put about 15 pounds of pull on it to get to come out.
- EnviroImports.com
there may or may not be a single screw holding it in place, take a look around the base , use a flash light if need be. but it does slide out for filling.
Noel
Noel
- Schwa
- Vehicle: 1992 Delica Exceed
I'm pretty sure the screw doesn't hold it in place (it holds the pump to the tank), you just need to give it a really hard tug, I thought mine was stuck at first, but I just thought it would break if I pulled it that hard... I guess it's a good thing it's not able to slide out too easily, heh
- patty
yeah i pulled mine right off the wall,but its back in there now. i got it out and everything and realized i didnt even have any fluid to fill it with .
