Gday all,thought it was about time i threw some pictures up of my D. Hope you like.
Some mods ive done
Sprayed the rims black.
Sprayed bullbar black and removed plastic shroud.
Removed side steps.
Removed entire aircon.
Ghetto Snorkel.
Tinted windows
Mitsi express van side mirrors
Removed the muffler
Painted roof with black ute liner.
Egt,coolant,boost and head temp gauges.
Double din stereo,dvd.tv gps bluetooth player ,New 5inch up front,6x9 in the back.
led bulbs in all interior,uhf radio
MY BEAST
- gezzza
- Vehicle: 92 exceed
MY BEAST
- P4130141 (800x600).jpg (296.42 KiB) Viewed 5740 times
Re: MY BEAST
Your beast is a nice looking rig, Gezzza ~ So you're running UHF, eh? Do you need a license for that in Aus? I have a HAM radio with UHF. Some UHF frequencies in Canada are license free (Family Radio Service) but the wattage is limited and consequently the transmissions are very limited.
A couple of members in Canada have had their roofs painted with a product called "Rhino Liner", which is originally designed for lining out pick-up truck beds, which I am presuming is the same or similar to your ute liner. Pretty tough stuff.
What is the reason for removing the A/C unit? I would think that in Australia the aircon would be an important feature.
- Luna-Sea
Re: MY BEAST
Hey,
Nice choice of data for gauges.
Do you ever regret removing AC?
Did it not work in the first place?
I have Been toying with the idea of removing
the air-conditioning for a long time.
Nice looking van man,looks like
You have a different rear bumper bar then I have seen,
Can you post a stern view pic too?
Right On!
Right On!
Re: MY BEAST
Very nice beast!
That would be a truck bed liner for which there are many products that could be used including hippo liner, rhino liner, EZ liner, etc.FalcoColumbarius wrote:A couple of members in Canada have had their roofs painted with a product called "Rhino Liner", which is originally designed for lining out pick-up truck beds, which I am presuming is the same or similar to your ute liner. Pretty tough stuff.
- gezzza
Re: MY BEAST
The uhf requires no licence but 5 watt is max.I dont seem to pick up much transmissions on it either ,my anttenae is a little short sitting below the roof line.As for the ac i might regret it one day but i have a couple of little 12 v fans to install. First it was only the rear set up plus ac condensor under the passenger floor but i got carried away and dumped nearly half a ute load altogether when it was all gone.Now i have space for my aux battery and maybe air compressor or i might turn it into a toolbox.The old bloke never had a belt on it when he owned it, and i was to lazy to try and check it for working.But there is so much more room every where and heaps easier to work on .Saved a few kg as well. The sliding drawers and storage boxes should be installed by a week or 2.
Here is the rear bar ,could be a super exceed option with those chrome ends on it.
- shealy
- Vehicle: 92 Delica Exceed
- gezzza
Re: MY BEAST
Gday shealy 5 inch is the standard size.
- shealy
- Bessie the Mud Slayer
- Vehicle: 93 Exceed.
Re: MY BEAST
I think stock is 3.5 front, 5 mid, and optional 6x9's in the rear at the roof. 5.5's will fit easilly in the mid with a little cutting of the mount plate, but there's no way anything bigger than 4 is fitting in the front without some major mods.
