I researched what tires could replace the cracked ones on my 1997 L400 (hasn't landed yet).
I narrowed it down to 4. Most my driving will be in the lower mainland, however I will be going off road once in a while.
Firestone Destination A/T 235/75R 15
Firestone Destination M/T 235/75R 15
Goodyear Wrangler DuraTrac 235/75R 15
Yokohama Geolandar A/T-S 235/70R 15
Below are pics of the existing wheel and tire.
Thanks for the input ahead of time.
Paul
New tires for my 1997 L-400
- pham
- Vehicle: 1997 Delica L400 Exceed SWB
- Tire.jpg (52.73 KiB) Viewed 4254 times
- Tire and Wheel.jpg (87.52 KiB) Viewed 4254 times
Re: New tires for my 1997 L-400
I vote for Duratrac's
I'd vote duratracs as well. Avoid m/t tires if you're not offroading much as they are not great for road use.
- rezdiver
- Vehicle: 1991 L300
Goodyear Wrangler Territory from canadian tire. i believe it has the same tread compound and carcas as the duratracks. half the price.
Reza
1991 Delica L300
http://www.iltisforum.com/
Reza
1991 Delica L300
Shop around too. Fountain Tire on marine price matched and beat even the lowest US price I could find after taxes.
- LeeHammy
Great info guys thanks!!! I face this dilemma right now. I am in the process of upgrading suspension which will leave me out of alignment and with more room then my little 265/70R16's need so tire upgrade and alignment is the plan.
I then found out that the tires Kal Tire put on when I first made it road worthy were 4ply.. My truck needs 6 minimum. Opps. so they will credit $75 per tire to me. Still feel burned. I am thinking of Wildcat Sport 6ply in the 75R because it is what I had and was great for a low key name brand or 10ply R75 BF TAKO. But the BF suck in snow I hear??? Your info is perfect timing as I am thinking of checking these out. Any complaints on the BF's? (in the snow and slush?) Not wanting a noisy hard ride per-say.
i like cheese
I have no complaints with the BFG A/T's in snow. They're great tires in my opinion but I know that others would say the Duratracs are better.LeeHammy wrote:Great info guys thanks!!! I face this dilemma right now. I am in the process of upgrading suspension which will leave me out of alignment and with more room then my little 265/70R16's need so tire upgrade and alignment is the plan.
- tonydca
X2 on the Territories, although I'm sure the Duratracs are skookum too. I've had my Territories for a while now, on and off road and I have no complaints.rezdiver wrote:Goodyear Wrangler Territory from canadian tire. i believe it has the same tread compound and carcas as the X2 on theduratracks. half the price.
FWIW, neither tire will fit into the spare "basket" under my L400, so I got a smaller-sized non-off-road tire for that purpose, as the old Japanese one I had there was the original 15-year-old one and starting to crack with age.
Not the ideal drivetrain choice for a spare to run a tire of different diameter, but for temporary use its better than nothing.
Feds
I went with the General Grabber AT2s in 265/70/15. On stock suspension with no hammers, I get a little rubbing at full lock, mostly in reverse.
They are excellent in the snow, took them offroad through about a foot with no issue.
They are cheap as chips from the tire rack too.
mrraulduke
- Vehicle: 96 L400 SWB
what are those rims?pham wrote:I researched what tires could replace the cracked ones on my 1997 L400 (hasn't landed yet).
Paul
I love the white
