MUT2 Scanner in the Vancouver area?
riverrio
Vehicle: 1998 Delica L400 2.8L TD
Post by riverrio » Tue Jul 16, 2019 2:43 pm
I have a '98 diesel and my SRS airbag light won't turn off. This forum: http://www.delicaclub.com/viewtopic.php ... &p=169228 suggests I might be able to reset it with a Mut scanner. I called CVI, Rising Sun, Japanoid, and the Langley Mitsubishi dealer, with no luck. Does anyone know somebody in the Vancouver area with a mut2 scanner?
saltypeanuts
Vehicle: L400 Series 2
Post by saltypeanuts » Thu Sep 05, 2019 9:47 am
I managed to clear an airbag code without a MUTII on my 2000! See this info from my previous post:
Posting for information. I triggered an SRS light messing around with the electrical system. Today I was able to connect to the SRS module and clear the code. My van is a 2000 Series II, Diesel. Wasn't able to connect to the OBD module, maybe a MUTII is still required for that.
The scantool is an Autel ML 619, $150 on Amazon. If anyone in the Calgary area needs their SRS or ABS codes checked or cleared, PM me and I'd be happy to help.
Return to “L400 Technical”
