The van doesn't use the same technology; I would anticipate you want to use a K type thermocouple in each case. EDIT: you know what, if you are good with electronics, you could tune the meter to work.fexlboi wrote:Can you use the existing thermostats?RichD wrote:Bonus
[ Boost ]
[ Inside / Outside temp ] - on a switch
Does that mean you can use one gauge with multiple sensors? That would be awesome.
If you use multiple sensors of the same class (e.g. all the low temp liquid/air thermocouples) you can switch it with a multi-pole switch.
ON/ON Switch - 6 pins: 2 out, 2 x 2 in
Position 1, Sensor 1 (e.g. external air temp).
Position 2, Sensor 2 (e.g. internal air temp).
Gauge - 2 pins for thermocouple +/- to switch output
Sensor1 - +/- to switch input position 1
Sensor2 - +/- to switch input position 2
