Started on making a Mitsubishi RVR Sports Gear spare tyre carrier fit on the Delica. Some modification required.
dharmadelica
Vehicle: 1992 L300
Post by dharmadelica »
Well, haven't posted much lately but have done a few things to the van.
The best curtains... Coroplast! I cut pieces for all windows, fit like a glove, let natural light in, and are impossible to see through. Also tore up the carpeting throughout and stripped the paint. Primed and sprayed boxliner in the front and a bit in the back. Put down 3/4 " plywood (maybe a bit overkill) in the back with plans to hard mount it to the floor. Put the rear carpet over the ply in the meantime. Daily driver since 2007 so I'm playing the long game with Nazomi (my Delica).
Put a turbo boost guage in with the guage mounted on the side of the shifter housing. I have a sensor for a pyro but haven't installed it yet, and I might not want to know......
Rear door piston bracket reversed for more head room.
Rear 6x9 speakers mounted from the ceiling in the back, found perfect fit bolt holes under the faux ceiling and cut around it to make it fit.
I've had a number of different tires over the years, but my current faves are Goodyear wrangler 235x75r15 in the summer and snow claw studded 235x75r15 in the winter. For 2wd winter traction I have been running 2 - 3 rubbermade totes full of sand over the rear axle, works great! I wired a small solar panel to the dual batteries and mounted it on the dash on the passenger side, and this summer wired a cigarette lighter 12v plug just behind the passenger seat by the seat belt. Power, anytime. Ski pole grip as the 5spd shift knob. Painted the bush bars and most of the front metal black. Repaint prn. Class 3 rear hitch made by that guy in Salmon Arm several years ago, it's never let me down. I have an original wasp nest up in the side door well, no longer occupied but I like the aesthetic, as well as one that keeps hanging on under one of the upper rear cowlings top outside of the rear door. Oh, and my feet don't get wet anymore. I'm sure there is more but I can't remember. Next up is a safari rack. Anyone have one they will part with real cheap?? Let me know if anyone wants photos of anything. Love the site and community here, long time member, sticker proud on my passenger side view mirror!
stever1000
Vehicle: 94 L400 SuperExceed
Post by stever1000 »
I used a can of SeaFoam in the crankcase and changed the oil and filter. I also put a can of seafoam in a new fuel filter and installed that.
Can't wait to see if this fixes my poor fuel economy!!
stever1000
Changed the front and rear pads, and the front rotors.
I local Delica mechanic said my brakes were at <40% when I did a prepurchase inspection, and when I actually pulled the pads they look to be at 50% even after driving it a few thousand km's since purchase. I replaced them anyway and will use the old ones as spares I suppose
TieMyShoe
Vehicle: L300
Post by TieMyShoe »
..ended up with three of em at the house some how...
deli #1 got
HID head lamp install
transfer case repair
turbo rebuild
front lift kit and shocks
coolant flush (in need of 4d56 block if anybody has one kickin around)
Deli #2
new VC gasket
exhaust leak repair
turbo feed line repair
sub removed and seats installed
rear brake service
rear window water leak reapir
Deli #3 (mine.. finally)
Trailer light wiring install
still not done... back to the garage..
islander20
Vehicle: 1994 L400 LWB
Post by islander20 »
Finally got my front brakes hooked up...just torqueing the last lug nut and snap there it goes. F*ck! So sick of taking the hubs and brake apart and I dont have time now to fix it. I decided to drop it off at Kal Tire, nice and easy. Then on the way there one of my power windows stops working, will only go down half an inch. Double F*ck....now I get to learn how power windows work.
Shaun Van Ramen
Vehicle: '91 Exceed
Post by Shaun Van Ramen »
islander20 wrote:Then on the way there one of my power windows stops working, will only go down half an inch. Double F*ck....now I get to learn how power windows work.
Left or Right door?
If the left, I might have some parts you need.
BAHahahahahahaha
gezzza
Vehicle: 92 exceed
Post by gezzza »
Blew a head gasket last week so I just replaced that the other day. Rebuilt alternator should be ready on thursday so all will be good again by the weekend.
islander20
Left or Right door?
Its the right. It seems like it just jammed, hopefully no need for parts. Cross my fingers. Wont be able to take it apart for a week or so.
shaner
Vehicle: L300
Post by shaner »
I got my van registered in Sask!
. I had relatively little trouble! i added LED DTRL and wired my side markers in. Other then that i had some condensation in my headlight, a u joint that needed replacement, and some loose wheel bearings.
about 2 hours of my own time for wiring and 270 bucks at the mechanic.
I am pretty happy
thelazygreenfox
Post by thelazygreenfox »
Last week I installed a new engine temp sensor. There is a slight improvement in gas mileage so I'll change the other 2 as well and see.... :-D
2 days ago the rear passenger side caliper wouldn't reseat so yesturday i rebuilt all 4 brake calipers, bled the ABS brake lines, never seized the wheel studs and reinstalled the tires. I double checked the stud nuts torque this morning. :-D
The kit and sensor were from Amayama trading.
TLWF
Shaun Van Ramen
Vehicle: '91 Exceed
Had the front brake callipers replaced. I knew one side was sticking and had no time to do it myself. Good thing as I found out I also need front bushings. 173,000km. GO figure!
BAHahahahahahaha
kurtographer
Vehicle: l300
Post by kurtographer »
Before and after, thanks for the heat gun info!!
Tomahawk
Vehicle: Delica L400
Post by Tomahawk »
^That looks great.
How was the heat gun process?
Knibby
Vehicle: 1996 Jasper
Post by Knibby »
Hitch installed. Another satisfied customer of EH hitch shop in Burnaby.
