nxski
Post by nxski »
Profister wrote:All 4 festoon LEDs I have ordered from SuperBrightLEDs have died within a year. I had to put back the cheap ones I bought on eBay. Not as bright as SuperBright ones but at least they work.
I've had every light in my vehicle changed to theirs and only 1 has stopped working, I got quite a few hours out of it though. The ones I bought from Autolismo are all still working as well, but there was some bad soldering that caused a couple of the led's within the bulb to go out.
If you're looking for a complete unit, http://sewardoffroad.com/twin has some good products at decent prices. I've tried ordering these types of lights on Ebay, but didn't save that much and they all leak. I just ordered some very bright LED H3 headlight bulbs on Ebay though, so hopefully those work out.
bionic
Vehicle: 92 delica exceed
Post by bionic »
..been running my superbright (16 cluster) festoon's for over a year without a single issue. I have them in every interior light. (7 total) Best interior "upgrades" ever...
http://www.ebay.ca/itm/20X-39mm-Dome-16 ... 626wt_1174
I'm running standard ten watt bulbs. What I really want are the stock eight watt bulbs. I have green gels over the map lamps in the cockpit which temper the light some but I still find them on the bright side, plus the lamps tend to get hotter with the ten watt bulbs.
Incidentally, I changed my oil and filter, rotated my tyres and repainted my drums and callipers.
macro
Vehicle: L400 "The Invader"
Post by macro »
Changed my front sway bar end links that somehow managed to s$%t the bed after less than a year. Good news is the front end clunk seems to have finally gone!!!
Beausoleil74
Vehicle: 1996 Space gear super exPajero-mini
Post by Beausoleil74 »
Painted the fades lettering on my fog lamp covers. If it ever stops raining in Edmonton I could undercoat and paint the brake calipers. Still trying to figure out how the TV in my delica works or what to do with it.
1995 Pajero-mini turbo
1998 Minica Toppo Town Bee
glenn
Post by glenn »
I sold it.
Guess I'm more old hippy than soccer mom.
Actually, it came down to finances. I like both vans for different reasons, so I can't say I'm that sad to see my L400 go. It sure was nice though - especially the passing loaded semi's part.
It is going to a good home - someone who has deep enough pockets to do all the preventative work that I just couldn't afford to get to.
And now, my L300 is getting a new lease on life.
Here is my last shot of it - our first, and last camping trip (Whitby Island)
Edit - one more last image
Glenn
http://www.vurv.ca
L400 and L300 consoles
Beausoleil74
It is/was a beuatiful Jasper!!
Hey - Rock & Roll choice Glenn. Hope you and that 300 have many adventures ahead :)
glenn
Post by glenn »
Thanks - I know we will - starting with beachside in Oregon next weekend.
In the spirit of this thread - today my L300 just got brought back to life. Here is the list of new parts:
New head - Complete (I didn't want to swap all the old parts into a new head - a little extra piece of mind)
head gasket
new head bolts
intake/exhaust manifold gasket and injector heat shield/gasket
timing belt/balance belt, oil seals
tensioners
water pump
new balancer shaft bearing and sleeve
oil pump O ring
injection pump main seal
fuel return pipe
valve cover gasket
cooling fan and clutch assembly
Fluids
I already had a new radiator and hoses - so I'm expecting to be trouble free for the near future.
I pick it up on Monday. After 6 months of sitting in my driveway, it will be good to be back in the saddle.
Glenn
http://www.vurv.ca
lrp374
Vehicle: 91 Super Exceed
Post by lrp374 »
I saw this stuff on TV and also noticed CT had it. The web site and You tube look pretty impressive. It sure looks good now. I'll see if the $20 is worth it and it really lasts 2 years. I did the black plastic on the Bambi bars with Armour All 2 weeks ago so I'll really have something to compare it to. The process is pretty easy and the little bottle really goes a long way.
Wipe New package contains everything to use it for plastic etc. and a headlight restore kit.
Back step before application.
Sample test on step and bumper.
Step after application.
Bumper, side panel and light bezel after application.
glenn
Post by glenn »
Resumed work on my utility wagon. Bulkhead flips forward over seats to make a bed.
utility wagon.jpg (76.89 KiB) Viewed 8065 times
Glenn
http://www.vurv.ca
nxski
Post by nxski »
glenn wrote:Resumed work on my utility wagon. Bulkhead flips forward over seats to make a bed.
Very nice! 8-)
macro
Post by macro »
Very nice! 8-)
x2
I always like seeing what you've come up with!
What do you attach everything to? Also, what did you cover your windows with? I wouldn't mind blocking off my rears ones as well.
psilosin
Vehicle: L400
Post by psilosin »
x3! All your work has a very classy modern design that makes me jelous (and my dog is jelous of your dog beds).
FredVenne
Vehicle: L300 Exceed Pop-Top, Pajero Exceed
Post by FredVenne »
I am refurbishing my turbo... This will take me a few days. Why? Because I'm taking my time (I can afford it) and I like to understand how the rest of the stuff is organized and I can clean around at the same time. Oh and I drink beer everytime I do some work on the Yeti.
Cheers!
-The Mighty Yeti
