The good thing about spending $120 a shock is that you can have all that and more.
I would concur with "oh wise Germanic Delican" and make them softer in the rear. Every configuration I use with my system is such, with the exception of when I am towing something heavier, but generally softer in the rear ~ the more comfortable the ride. Also good for digging in for spring when climbing.
							Wow thats Easy.
Re: Wow thats Easy.
- dennis_lambert
Re: Wow thats Easy.
The ones I have for sale are $120 for 2 not a piece!RichD wrote:Can someone recommend a shock that doesn't cost 120$ apiece? Not that I wouldn't pay that but several people have suggested that I shouldn't have to.
I'd like to replace mine as the fronts are sucky and the lower bushing is done.
They are Tokico stock length front gas shocks direct fit no adapters needed manufactured in japan.
Cheers!
Re: Wow thats Easy.
Miss Lil' Bitchi Parts File:
Rancho Shocks Numbers: RS9000XL(RS999188); RS9000XL(RS999151)
- TardisDeli
Re: Wow thats Easy.
The L300 TardisDeli had the Procomp 9000 for the first year, but it kept eating the bushings (yes even with the replacement higher quality polyeurethane bushings).
For past 2 years still running on the same Monroe shocks as recommended and installed by Glen at CC Autos. Way cheaper, available from any Napa etc (find a friend with a group account for more discount).
Will post the parts number in a couple minutes.
Christine.
EDIT: can't find the parts number (ooohh my messy deli)
But here is the the list Kevin BC Delica created in 2007 of L300 parts (thanks Kev)
Shock Absorbers Front
KYB 344111 or 344113
Bilstein F B46-1332
Ironman F 12082GR
GABRIEL GAS RYDER LT G63418
Pro-Comp part numbers Front 313515 (confirmed)
Monroe 550012 and 33074 (Fronts and rear)
Shock Absorbers Rear
KYB 343226 or 344226
Bilstein B46-1467
Ironman 12076GR
Pro-Comp - Rear 319520 (confirmed)
end.
Christine.
Bilstein F B46-1332
Ironman F 12082GR
Bilstein B46-1467
Ironman 12076GR
end.
Christine
- White Mule
- Vehicle: 1991 Delica L300
Re: Wow thats Easy.
I went to Napa today. The 550012 number came up as shocks. The 33074 number came up as nothing. Is there a digit missing?TardisDeli wrote:Monroe 550012 and 33074 (Fronts and rear)
White Mule
						White Mule
- Firesong
Re: Wow thats Easy.
The 33074 number is wrong. I had partsource order them
in for me and they are both eye attachments on the ends.
Don't try and order it.
FS
FS
				Mr. Pistachio
- Vehicle: L400 LWB Super Exceed
Re: Wow thats Easy.
Is it ok to assume for procomp ES9000 shocks?
stock
913515
919520
w/ 2'' lift
915515
919520
Antoine
						stock
913515
919520
w/ 2'' lift
915515
919520
Antoine
