5/8" hourglass poly bushings
Warning! ProComp shocks problem
Re: Warning! ProComp shocks problem
Both are the same
- Vehicle: -
PV2028 is the correct part number for the 5/8 bushing
- Erebus
- Vehicle: 1992 Super Exceed
To resurrect an old thread, the bottom rubber bushings on my front Pro-Comp 9000 shocks are in bad shape. Napa doesn't know from PV2028. Any suggestion where to get these bushings in Calgary? An off-road shop?jfarsang wrote:PV2028 is the correct part number for the 5/8 bushing
Also, should the upper bushing (pin-type mount) also be replaced? It doesn't look bad compared to the bottoms, but if I'm changing, might as well do it all.
"I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".- jessef
uppers donut bushings are fine rubber/poly.
hourglass bushings are the problematic one's.
any 4x4 shop will stock them. NAPA/Lordco should have bunches of them. They are a generic eyelet shock bushing at 5/8"
The PV # is specific to procomp. If store you are shopping at does not stock Procomp shocks, they won't bring up this part number.
legionnair
- Vehicle: delica L300
As a side note never install py bushings in dry, use a good quality silicone grease inside and out. Will improve life and stop the squeak.
Dustin
Dustin
Good luck getting them in position without some grease anyway!legionnair wrote:As a side note never install py bushings in dry, use a good quality silicone grease inside and out. Will improve life and stop the squeak.
legionnair
It was more a general info for poly bushings normal grease is ok but silicone grease will protect and lube betterRichD wrote:Good luck getting them in position without some grease anyway!legionnair wrote:As a side note never install py bushings in dry, use a good quality silicone grease inside and out. Will improve life and stop the squeak.
