grease points on delica ????
Profister
Re: grease points on delica ????
Post by Profister »
So, it is confirmed that my Delica has only 9 grease points because the upper ball joints are aftermarket ones. Hmm. I wonder why, the odometer showed 72K when I bought it...
patty
Vehicle: delica chamonix
Post by patty »
so im alittle lost here. its said just buy metric nipples when replacing them. is there not a size or gauge to go off? metric seems alittle loose seein last time i wa sin princess auto they had a huge shelf of different sizes.
patty
Post by patty »
never mind about the nipple size, got it covered and bought. the only problem is i can find all the grease points right up to the rear drive shaft. i can only find one in there. could anyone throw some of those helpful red circle into the previous picture so i can get a better idea of where to look.
nishby
Vehicle: '92 Super Exceed
Post by nishby »
Patty,
I'm not much good with the graphics, but there are three nipples. The one you found is likely the obvious one on the outside of the knuckle. The other two are tucked inside the knuckle (one front and one back). You'll find them if you feel in between the universal joint connections. Hope that helps.
Shane.
madmazda
Vehicle: 1994 l400
Post by madmazda »
what about grease points on the l400 ?????
BFG
Vehicle: L300 Starwagon
Post by BFG »
L300 Grease points..
Ref the front grease points, they are mirrored on the oposite side so theres 11 in total.
UK Based
K Reg Mitsubishi Delica Starwagon 2.5T D.
Dreaming of what MOD to do next!
madmazda
Vehicle: 1994 l400
Post by madmazda »
well I guess there are a few on the l400 so when i get it I guess I'll be poking around to find them
If your ball joints have been replaced (upper or lower or both) you probably won't have grease nipples any more, and this would lessen the number of grease points. For example, I only have nine now instead of the original eleven - upper ball joints replaced.
madmazda
Vehicle: 1994 l400
Post by madmazda »
Well I'll find out in a week or so as it will be shipped next week....I'll get my light have a peek under neath
Erebus
Vehicle: 1992 Super Exceed
Post by Erebus »
BFG wrote:L300 Grease points..
But the diagram only shows 10. I thought there were 3 on the rear driveshaft. Or was it 3 on the front driveshaft? Either of which would make it 11.
dfnder
Vehicle: '91 Exceed
Post by dfnder »
What size are the grease nipples? I need to replace two on the ball joints from L shape to straight ones.
dfnder wrote:What size are the grease nipples? I need to replace two on the ball joints from L shape to straight ones.
So... do you not have the L shaped ones in your possession? Just take them in and say: "I want these, accept straight". Out of curiosity, why are you trading out the L ones for straight ones?
dfnder
Vehicle: '91 Exceed
Post by dfnder »
I have the 'L" shape ones and they are attached so I didnt want to remove them but I'm getting the drift that they can be removed with no harm done, is that correct? I just didnt want to drive around without them on but I guess once the grease has been placed it really wouldnt run away!
I was going to put in straight ones because the front shim for my lift will make the L unusable.
Yeah, they unscrew in the usual fashion. Just make sure that the surface that they are screwed into is clean so you don't get dirt into the hole when you are removing or replacing. Drive to your destination of purchase, unscrew nipple, go inside and ascertain if they have what you want, come back out and replace either new or original nipple, drive away.
Airgonzo
Vehicle: '95 L400
Post by Airgonzo »
Hi folks,
I'm reviving an old thread here that I found after getting under the front end of my L400 and realizing that on both sides the rubber boot protecting the upper ball joint was not properly sealed (see photo). I managed to get both sides seated properly and then, after losing a lot of grease in the process, thought I better add some but was confused to see that mine is not equipped with a grease nipple. See above posts. This apparently means that at some point my ball joints were replaced, which is strange because I bought the van with 89,000 km on it and it would have been done before I bought it.
My question is: How should I go about repacking the ball joint with grease? or should I not worry about it?
It would be great if anyone could shed light on why these are being replaced at such low mileage or should I question the accuracy of my odometer?
Z
