Metal Fabrication / Skid plates - ***Drawings***
L300Foca
Vehicle: Mitshubishi L300 2.5 TD GLX
Re: Metal Fabrication / Skid plates - ***Drawings***
Post by L300Foca »
AWSOME POST
TNX
FollowMe
pajerry
Post by pajerry »
Love the individual touch on those ones. What was the total damage all said and done?
The way I off-road is that if something is steep like a ditch, I will inch into it, if I hear a scraping sound I stop
Your inching down causes your van to want to endo :) I Wish I had captured some of the better examples from that day, there were a few good ones riding the brakes.
nxski
Post by nxski »
Very true, the inching was to save the radiator guards of which I did sheer off one (it's back in place now though). There was absoloutely no damage to the skid plate thankfully.
I suppose whipsaw was more like inch-inch-inch-clench and let go of the brakes. :-D
pajerry
Post by pajerry »
too true. Very entertaining 8-)
Tojo
Post by Tojo »
Downloads for a PDF fully dimensioned drawing, PDF one to one scale drawing and DXF outline file for a waterjet cutter (in a ZIP folder).
All for an automatic transmission L300 Delica.
*EDIT: Bend diagram attached. Drawings have been revised June 11th, 2012
Thanks to NXSKI for releasing this for FREE to the world. LOL!
Happy Bashing!
L300_auto trans skid plate_one to one PDF_120611.PDF
(60.33 KiB) Downloaded 813 times
L300_auto trans skid plate_one to one DXF_120611.zip
(15.31 KiB) Downloaded 558 times
L300_auto trans skid plate drawing_120611.PDF
(79.39 KiB) Downloaded 714 times
L300 skidplate bend diagram.pdf
(264.62 KiB) Downloaded 795 times
almac
Vehicle: '91 Delica "Tessen"
Post by almac »
8-)
will the designs work on a laser cutter? and do you have designs for the 5sp manual transmission? :?
al
nxski
Post by nxski »
almac wrote:8-)
I can send you the rough AutoCAD plans for the 5 speed or of you're bribe Tojo he might be able to finish them off for you!? :-D
The problem is that Tojo modified my drawings and added dimensions based on my trial and error. I have no existing skid plate that I have created for a 5 speed, just dimensions that SHOULD work. :?
shealy
Vehicle: 92 Delica Exceed
Post by shealy »
So if we take that .dxf file that Tojo just posted to a place that does metal fabrication and has a waterjet cutter, then they should be able to do it? (minus the bends of course....)
By the way: thanks for these plans!
almac
Post by almac »
i think my machine uses .ncf files. i'll look into some kind of conversion...
al
nxski
Post by nxski »
The Waterjet cutters I took mine to used AutoCAd drawings. It appears that there's no industry standard.
Tojo
Post by Tojo »
Hey Guys,
I can do up the manual transmission drawings on Monday when I'm back at the workstation doing 'work' ha ha. It appears that it's mostly the same except for the cutout. However, the manual trans version hasn't been made and tested yet, NXSKI and I both have autos, so you'll be the guinea pig. Most of the waterjet cutters that I've worked with can use DXF or DWG files. I'll look and see if I can convert to .ncf, probably can.
As for waterjet vs. laser cutting: http://www.teskolaser.com/waterjet_cutting.html
Waterjet can cut thicker material. But a laser cutter can cut up to 0.4" material depending on the strength of the machine.
On a side note, it would be cool to cut a Mitsumaple logo into the top of the plate. Also, if there is interest, we should get a bunch of skidplates made at once to bring the cost down.
Tojo
shealy
Post by shealy »
Well count me in as interested if we do some sort of group fabrication. I like the idea of a mitsu-maple or something on the plate - I'm sure more airflow holes to that rad, the better too. Keep me posted, cheers!
-Steve
almac
Post by almac »
i work on a laser machine daily that is capable of cutting up to 1/2" steel.
while the mitsumaple sounds cool, i would rather just have a regular maple leaf.
please keep me posted.
al
Tojo
Post by Tojo »
Manual transmission L300 production drawing, one to one PDF and DXF file (in a ZIP folder) attached.
NOTE: this has not been tested, so it's highly recommended to make a cardboard template for proof of concept!
(264.62 KiB) Downloaded 631 times
Pa_manual trans skid plate_L300_one to one_ASCII.zip
(9.1 KiB) Downloaded 567 times
Pa_manual trans skid plate_L300_one to one_REV01.PDF
(59.33 KiB) Downloaded 634 times
Pa_manual trans skid plate_L300_REV01.PDF
(81.85 KiB) Downloaded 628 times
L300Foca
Post by L300Foca »
Tojo wrote:Manual transmission L300 production drawing, one to one PDF and DXF file (in a ZIP folder) attached.
TNX Bro
FollowMe
