Another Plant Drive kit install
- patty
 - Vehicle: delica chamonix
Re: Another Plant Drive kit install
this was very helpful, thanks
				PlantDrive
 - Vehicle: 1991 Delica
There is a message earlier in this thread about the buzzer sounding when on veg whether the van was on or not, and it seemed the poster thought that was a problem...
Actually, It is supposed to do sound, if left on veg, when you turn off the van; that's the idea of it. you are thereby warned to restart the engine while it is still warm, do the purge on diesel fuel, and then shut off the engine again.
Edward Beggs
PlantDrive.ca
Salmon Arm BC
plantdrive.ca@gmail.com
						PlantDrive.ca
Salmon Arm BC
 - Vehicle: -
Do you remember which one is the return line?Adam wrote:UPDATE: I've got most of the electrical and plumbing complete. I was surprise how easy it was to cut the coolant lines and stick in the tees to divert some coolant to the heated VegMax filter. Using the cheapo vice grips I picked up from CDN Tire (5 for $10), I clamped the coolant line so that I had enough room to comfortably install a tee.
				Adam
No I don't.  Not sure if I ever figured it out, or if it matters.  My VegMax filter heated up nice and hot, I never had to trouble shoot it.
