Provent oil catch can
- delicat
Re: Provent oil catch can
Good work Sergiy, thanks for posting! Nothing like keeping your pipes clean!
- Pajerist
please post pics!madmazda wrote:I've made one out of copper fittings and a k&n filter on top... now to just find room to mount it
- Pajerist
Same here! Please post pics/share you results...Strada 92 wrote:Strada-Caster,really interested by your catch can.
Do you have some picture?
Thanks.
- Pajerist
Paul, how metal elements in your catch can do the job of paper filter? Have you noticed performance improvement? How often do you drain oil from the can?mararmeisto wrote:Same reason there is a paper filter in the air intake pipe.
- Strada 92
I've installed a Provent 200 catch can on my Strada.Truly effective.Not a lot of oil,enough to wipe with a rag once a month.The rest of oil is trapped into the little filter inside of the Provent. But there is a bit more water coming from the condensation of cold air
entering the engine thru the intercooler at low outdoor temperature.Mostly,it's a litlle piece of ice that i remove.
I wanted the systeme to be closed,not open to air and I do not want to return this crap in the oil pan so I plugged the small drain tube and clean the Provent once a month.
Mitsubishi L400 Spacegear
Mitsubishi I-MiEV 2012
