Remove used front and rear 4.625's out of a US montero and put on 30" tires coupled with the 5-spd is a hard combo to beat.
The reason why you don't hear much about these things is t because people assume L300's are unique. They are not. They are based on the same 1st generation montero/Pajero and share most driveline components (diffs, axles, brakes, 4wd parts, etc...)
Airwick wrote:Now you've spiked my interest...jfarsang wrote:
As for gear ratio's on the highway, you guys are confusing people.
The driveline gear ratio's (gears in the front/rear differentials) in the US is 4.625 and 4.636
In JDM Mitsu's, they are 4.875 and 5.29
If you simply swap out the JDM gears (5.29/4.875) with the US (4.625's), you will have a 5psd that can cruise nicely at 70mph under 3k with good mpg.
If you can get a 5spd for your trip, do it.
I got a 5 speed L300 as well because I hate autos and I am doing some towing but I sure wish it would cruise a bit faster at lower RPM on the highway. It's the first time I read something about this conversion opportunity and I'd like to hear more about it.
Have you done it yourself?
Am I correct in my understanding that you just need some bits from the front and rear diffs of a US Montero to fix that? I'd like to hear someone confirm this as it sounds quite easy so I am surprised no-one here mentioned it before.
