Clunking in the rear on L400's going over bumps is normally excess play in the rear sway bar links and rear sway bar bushes.Just grab the rear sway bar and see if there is any movement up and down on both sides.
Hope this helps to put an end to you going crazy!!!!
Is there another L400 in Calgary?
Pacific JDM Parts
aclarker
- Vehicle: L400 Super Exceed
Re: Is there another L400 in Calgary?
Hope not. The Clunk started to happen post Pro Active... Maybe, I'll get up on a hoist and take a look.
madmazda
- Vehicle: 1994 l400
well i live in calgary and am going to be a new owner of a delica spacegear really soon...... I'm hoping I can find a block heater.... hopefully an in line one will do the trick
- Erebus
- Vehicle: 1992 Super Exceed
In-line heaters suck compared to block heaters. Don't bother with an in-line, waste of money. Block heater is the way to go.madmazda wrote:well i live in calgary and am going to be a new owner of a delica spacegear really soon...... I'm hoping I can find a block heater.... hopefully an in line one will do the trick
"I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".-
talk to mardy, he's now done a block heater on my new L400, so I'm sure he can give you pointers on how to install one...
- DelicaFreaka
- Vehicle: 94 L400 4M40
Here, check this out. It is a fairly simple install if you know your way around some simple tools. I will be doing mine shortly. Just remember that after you drain the rad and pull the line off the rear heater unit you will still have some coolant gush from the right rear frost plug when you bang it out. Put a tarp down to catch or stuff some towels under the plug to soak most of it up as it comes out. A little tight to get at but definitely can be done. No lifting of the vehicle required. Good luck...........................Kirk out.madmazda wrote:well i live in calgary and am going to be a new owner of a delica spacegear really soon...... I'm hoping I can find a block heater.... hopefully an in line one will do the trick
****Block Heater Part # (found at Lordco) 3100049..... $35.00 ****
http://www.delica.ca/forum/block-heater ... -6592.html
********** Starship Delica **********
"To boldly go where no man has gone before"
