Just a note that both the starter relay and glow relays feed through a fusible link at the battery(s) and if that link is broken or contacting poorly, you will get no glow, no crank, no start (unless you have a manual trans, or jumper the solenoid on the starter to engage it) ...
~John
Won't turn over, help please. all fixed ,thanks
RaddCruisers
Re: Won't turn over, help please. all fixed ,thanks
E4 Auto Repair Ltd.
& Radd Cruisers 4WD
Duncan, BC
250 746 8977
& Radd Cruisers 4WD
Duncan, BC
250 746 8977
- Luna-Sea
- Spearo
- Vehicle: 92 Smellica Exceed
Re: Won't turn over, help please All fixed!
Occam's Razor strikes again.visotzky wrote:Thanks to a Call to Glen at CCAutos , My deli is all good again. turns out one of the connectors coming off of the + terminal was corroded.
Thanks everyone for your help. I learned alot.
Val
Glad it's running :)
Blackberry
- Vehicle: '92 Exceed P35W
Interesting. I've a 5spd as well and had been wondering if it was possible to do so with such a high compression engine. What gear did you bump-started it in?visotzky wrote:... luckily it's a standard and got some help to push me down the hill to start via compression.
Thx!
