thanks for the tips. the 1000 doesnt have a LCD (liquid crystal display)JMK wrote:I used a Xantrex 1750W Inverter and a 175A fuse I found at Canadian Tire. After 9 months the fuse has not blown so far. I've noticed if you are running the inverter, and you start the engine, the inverter's error light (faulty circuit light?) will come on and you need to turn the inverter on and off again.
One thing I've noticed now regarding Xantrex products. Besides the inverter, I also have a 12V Automotive Charger of theirs. On both of them the LED (or is it LCD?) displays are so faded out and dim that you can only read them at night. THis seems to me like more than co-incidence, leading me to believe Xantrex is using substandard display panels in these products. Chances are, you may end up with the same problem.
how and where is yours installed JMK?
