I have the ProComp's and they are excellent all-around tires.dfnder wrote:If I get a 7" rim will I need to have an offset as well, I'm guessing 1/2" to equal out the rubber gain width wise. I'm thinking of getting 30x9.50R15 and a set of ProComp's which got high reviews in another thread.[/color]
15x7 with 3.25 - 3.75 " backspacing is perfect for 30x9.5x15's
If the last time it was serviced was at 107k and you're now 8,000km's into it, I would replace :pelex wrote:I am wondering how much I should attempt to change locally and why I should not trust Mitsubishi. Last time it was fully services @ 107k, it is now at 115k.
-oil/fuel/transmission filters and fluids
-front/rear differential fluids
-flush coolant system
-new thermostat
-clean injectors/adjust valves/set timing
-inspect brakes and replace if needed
This is normal maintenance at 10-12k interval which you are at now.
if the wheels bearings have not been replaced yet since new, I would replace them
Shouldn't cost an arm and a leg and it will extend the life of your Delica by a long shot.
