Biodiesel problem
Schwa
Vehicle: 1992 Delica Exceed
Re: Biodiesel problem
Post by Schwa »
coaxial wrote:
Schwa wrote:I have bought B20 from autogas propane in Burnaby and my van ran just fine on it, no extra smoke, some power loss and fuel consumption went way up
I just tried bio for the first time, filled up on B20 at autogas on main street. Ran exactly the same but I got significantly less fuel economy.. 100km less range on the tank!
Anyone know why this might be?
Same thing with me - probably because there's less energy in the bio portion, so you end up stepping on it a bit harder to make the van go the same speed as you did on dino. Similar to the effect of using ethanol in gasoline engines that can somewhat adjust for it. If you use it consistently you can make some adjustment to the settings on the inj. pump to increase max fuel injection because of the lower energy content and lower EGTs.
Return to “WVO and Biodiesel”
