Trailer Wiring
maw
Vehicle: 1963 Unimog 404.1 & 1992 Delica
Re: Trailer Wiring
Post by maw »
Hi all,
Can anyone confirm if this is the correct wiring kit? Pictures attached.
U-Haul Product#13486
http://g0rt.org/pics/hitch/IMG_3376.JPG
http://g0rt.org/pics/hitch/IMG_3382.JPG
http://g0rt.org/pics/hitch/IMG_3383.JPG
Re: Trailer Wiring
Post by Green1 »
that will work just fine.
maw
Re: Trailer Wiring
Post by maw »
Thanks. After reading a few other posts it seems like people are tapping into the left light housing and running one wire over to the right light housing under the metal strip?
Re: Trailer Wiring
Post by Green1 »
maw wrote:Thanks. After reading a few other posts it seems like people are tapping into the left light housing and running one wire over to the right light housing under the metal strip?
that's the easy way, though I suspect that the wiring all comes from the front of the vehicle to one of the sides and then splits to the other side behind the light somewhere, so theoretically you should be able to run everything to one side (likely the right side) and not have to run a wire accross.
