MardyDelica wrote:Hi, as you know, you think fuel filter will all get all the small particle Dibres & water. i dont think fuel filter can do all the work. the reason i say that i might cost you about 1000 of repair or more is that, if you got a water or other small particle came from your dirty tank that by pass the fuel filter. would it be to late for you to think that it, it might damage your fuel pump & injector as you cannot just see this.
this is just a precaution to everyone not recommend to do this.
as i did see some of this pump accur this type of problem when they do that.
just ask any local diesel truck mechanic says if thats true.1000 damage cost of repair is just estimate maybe more if you do this.
its your choice. remember the pump assy is expensive.
would anybody risk, i dont think so, we are talking about diesel with injection pump, not like gas even your run out of fuel, its o.k. butthe result it could plug your gas injector for gas engine.
this is just advice adam, that it will potencially expensive to fix, anyway nobody want to dry out of fuel when your driving this vehicle to prove the exact fuel economy. i dont thik its a wise idea.
just athough adam
cheers;
What I am having a hard time understanding is where is this water and debris accumulating? Perhaps you could answer a couple of questions for me so that I can get this clear in my own mind:
1) Where is the fuel pickup located in the tank? I suspect that it draws fuel from the bottom of the tank, but I've never looked inside my tanks to confirm.
2) Where would water and debris accumulate in the tanks? At the top, or bottom?
3) Wouldn't normal driving be enough to prevent much accumulation of water/debris in any one area? I know my veg oil tank sloshes around quite a bit when I hit railroad tracks or take a tight corner.
4) Why would the fuel filter not stop debris larger than 10 microns from entering the injector pump? Would it not just get plugged and starve the engine of fuel if large amounts of debris were sucked up?
I'mm not trying to be combative, I know this issue has been debated a few times before on the forum, I'm just trying to understand the logic of why this would be bad. Saying "better safe than sorry" doesn't really cut it for me.
BTW, I agree that it is not necessary to run the tank dry to determine fuel economy, all you need to do is fill up, drive for a few hundred km, fill up again and see how much fuel you used for how far you went.
