I know you have looked at the low pressure cut-out switch and ruled it out.  However I was thinking yesterday that the clutch uses a low pressure switch (or temp switch) to engage the clutch and a high pressure switch (or temp switch) to shut it off.  Remember the clutch cycles on and off.  When you select Air conditioning you should get:
1. AC clutch engages
2. High idle solenoid kicks in  (1100 rpm)
3. As cold air comes out of the vent the compressor cycles off and on automatically.
I think you may have a problem with whatever is used to cycle the ac compressor off and on.  Sorry I am not used to trouble shooting automotive AC systems.  I only know how air cycle machines work on transport category aircraft.  (no freon)
						Anybody know what this is ?
				bae146
Re: Anybody know what this is ?
Sent a pdf to your e-mail listed in your profile.  Has loads of information.  Montero and Dodge ram info and diagrams.  Hopefully the Delica will be similar.  If I knew how to post it I would.
