I neglected to mention that jacking up etc. was when all other options have failed.
This used to be a common problem with tercel 4x4s with un matched tires (snowies on the front / all seasons on the rear) and the drive line became so tightly wound up it was the only way to solve it.
In anycase, good luck, I hope it's something simple.
John
transmission is stuck in 4wd
sittingsilent
- Vehicle: 1992 Pajero
Re: transmission is stuck in 4wd
My tires are all the same size, so is jacking it up still relevant? Tryed all the tricks above, but no luck, still stuck.
Michael
Michael
You've got nothing to lose, however I think you've got an internal issue in the transfer box.
John
John
sittingsilent
I'll take it in to a tranny specialist when I get back from a trip I'm off to... Will post again after to let you all know what it was.
