Quick answers to fuel capacity and 4WD
trendkiller
- Vehicle: 92 Super Exceed, CBR929RR
Re: Quick answers to fuel capacity and 4WD
So do all Deli's have a low fuel light? I have been just going by the gauge.... but I am used to so called dummy light....
haven't seen it on the Deli yet..
- patty
- Vehicle: delica chamonix
sometimes it works and others not so much, i can be drivin it comes on turn off the car and hang out for a bit comeback and the light wont com eback on for like another 15 km
they all have them, but there's no guarantee that yours isn't burnt out. just remember though that these vehicles have a 75L tank, if you're not letting it get down to the point where you're putting in at least 65L (officially more like 68) then don't expect to see the light.So do all Deli's have a low fuel light? I have been just going by the gauge.... but I am used to so called dummy light....
delica 304
- Vehicle: 1992 delica GLX
jrman wrote:If you're getting the traction that it sounds like you are....then seems your 4WD is working AOK - which leads me to believe that your wheel lock lamp is simply burned out (reasonably common problem it seems). If that is the case, you'll still want to operate as indicated previously in this post and reverse your vehicle to unlock the hubs after taking it out of 4WD and once you're sure you won't need it again. The hubs will last longer and you'll have better fuel economy when unlocked. I found that backing up to unlock has been variable to extinguish the lamp - normally only about 3 metres, but once as far as 10M or thereabouts.
The really wierd thing is, I'm pretty sure that there is no wheel locked lamp in my dash cluster. You can usually see what lights you have just by looking at he reflection of the unlit lights, and there is not a one that implies that indicates when my wheels are locked. The closest I have is a green one that indicates that 4WD is engaged (or is that what I am supposed to be looking for ?)
- Erebus
- Vehicle: 1992 Super Exceed
The 4WD engaged light is directly below the gear indicator stack. Looks like a picture of the drivetrain. The Hubs locked indicator is a (literally) green "Wheel lock", and is an inch or two to the right of the 4WD light, below the tach.delica 304 wrote:The really wierd thing is, I'm pretty sure that there is no wheel locked lamp in my dash cluster.
On the subject of fuel capacity, I've had the low fuel light come on twice. The first time I put in 68.2 L after driving about 30 km with it on, the second time I drove 20 more km and put in 67.1 L. Mileage was 578 and 524 respectively. That's for an automatic Delica with the 75L nominal tank.
"I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".-
delica 304
Wow I only get 480-490Km per tank! I think it may be time for a tune up!Ruminante wrote:delica 304 wrote: Mileage was 578 and 524 respectively. That's for an automatic Delica with the 75L nominal tank.
but do you put in 67-68 litres per tank?Wow I only get 480-490Km per tank!
delica 304
Last time I fuelled up I put in 72L and was at the pump 460Km later. I did have the 4WD engaged for few days, but I usually put 70L in and get 480-490km for my troubles
4wd is not good for the fuel economy...
- Trapshooter
- Vehicle: 1991 Super Exceed
I usually use 2WD ,and fill with around 65L just run 400km...
Is that mean i have to go somewhere to tune the engine ?
- Erebus
I wonder myself since I get 12.8 L/100 km, and people claim 10 L/100 km highway. But does that include correction for tire size? My odometer is within 1% of accurate.Trapshooter wrote:Is that mean i have to go somewhere to tune the engine ?
"I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".- Trapshooter
I agree that...
My tire size is 235-75 R15 and i normally drive on the city.When my light on is around 400km and fill up with around 62~65L.
So is that because my tire or i drive too fast?
And do you think if i bring to do some tune up at the engine can help ?
Thanks.
Thanks.
Ruminante wrote:I wonder myself since I get 12.8 L/100 km, and people claim 10 L/100 km highway. But does that include correction for tire size? My odometer is within 1% of accurate.Trapshooter wrote:Is that mean i have to go somewhere to tune the engine ?
I have the same tire size, and at 400km I still have a quarter of a tank showing. Fill is usually about 45-50 litres. Given that, I would suggest you might have a heavy foot. You're not trying to make 60km/h by the other side of the intersection are you?
delica 304
Nah, I'm not generally in a rush, for one, the van is way to comfy, two, it's not a vehicle designed to go fast and three, I get a bit of perverse pleasure seeing the people behind me spaz out because I'm not trying to set a land speed record!
Okay regardless of your driving habits or tire size, that last one is just plain funny. And I too get a bit of sick glee from watching others have convulsions behind the wheel. Most funny are the 'monster' trucks, sometimes diesel, who mat the accelerator, huge cloud of black smoke, white knuckles gripping the steering wheel, and that little bit of surprise when they blow past only to realise they have to look 'through' the vehicle to see me on the other side, calmly driving and completely oblivious to their requirement for me to have been going much more quickly. I'm laughing inside, but I don't dare show it because some of those tandem pickups are BIG!delica 304 wrote:...I get a bit of perverse pleasure seeing the people behind me spaz out because I'm not trying to set a land speed record!
