Steven,Rising Sun Auto Import wrote:Hi Butch,CVI wrote:Hi Steven,
Just a clarification, Is it a 4D56 Hyundai injectors or what, may I ask, are you installing on the 4M40 engine ??
Thanks and best regards,
Butch
That is absolutely Hyundai OEM injectors for 4D56 , because Hyundai does not make 4M40.
We have installed them to numerous customer’s L400, one pajero2800cc in Kelowna, some of my stock and my L400 LWB.
I have seen lots of power increase and fuel efficiency from my stock.If you want to see, pls drop by on your way home.
Actually I don’t trust ultra sonic cleaning for 15-20 years old injectors here at all, and don’t like to rebuild them at higher price from local IP shop.
We had a technical assistance last Dec/2011 from Hyundai IP technician when we got an enhanced IP rebuilt skill and all related parts, who says no problem for mechanical Mitsubishi injection pump.
Pls keep in mind Hyundai & Mitsubishi have shared IP/engine technology since 1990 and nowadays Hyundai led Mitsubishi in all auto tech and part supply.
Thanks for your concern.
Steven
do you have any numbers regarding this statement?
usually a power increase and fuel efficiency do not go hand in hand when changing only a fueling component. and as it has been stated, by replacing the injector with one one of a different breaking pressure will definately change your IP timing. let alone the fuel delivery volume. please post up some specifications and numbers so we can compare.
Also why do you not trust ultrasonic cleaning. how many injectors have you sent in for cleaning and what were the results? what company did you use?
can you confirm the injection pump is a mitsubishi pump or made by another company?
