The pics I have posted are not from my install, they are from a Plantdrive install. I have not installed the vegetherm yet but plan on mounting it in the same place as Ed did. And yes it will be the last in line before the injectors.I think I like the position of the VegTherm you chose better then were mine is mounted and I'm thinking of switching it. One question though, it looks like on your set up the VO hits your VegThem before the Pollack valve. Is that right? I was told that the VegTherm should be after the Pollack, so the VO is as hot as possible before it enters the injection pump.
As for the other pics, did not get a chance to post yet.
Eric, that set up looks great! Totally compact. You have a one battery setup I am guessing. Mine is two so I do not think I would have the room.
Keep up the good work everyone. As Edward Beggs said to me, we are becoming quite the little WVO club with our Delica's. Thanks to the frontrunners like Kev for all their help. So much good info and collaboration is happening here. It is fantastic
Sean
Call me BCDelica-less
