UPDATE: I've got most of the electrical and plumbing complete.  I was surprise how easy it was to cut the coolant lines and stick in the tees to divert some coolant to the heated VegMax filter.  Using the cheapo vice grips I picked up from CDN Tire (5 for $10), I clamped the coolant line so that I had enough room to comfortably install a tee.
The I coated the tee barbs in teflon paste, and installed them.  It's a good idea  to coat one barb at a time with the teflon paste, otherwise you end up with a bit of a mess.  Oh well, too much has got to be better than not enough, eh?
I ended up leaving a bit of slack on all the hosing so that I could drop the filter for changing without having to disconnect the hoses.  I used some zip ties to hold the loops up in the battery cavity, we'll see how that holds up.
I've also installed and wired the Pollack valve and moved the VegTherm closer to the action.
The last step is to get a fuel tank that will fit without me having to re-route my exhaust.  I have a line on a 15Gal Jeep Wrangler tank, the same one that
Kevin used.  Hopefully I can pick it up tomorrow.  If all goes well I could get it installed this weekend and be running on WVO.
