- Vehicle: delica L300
Next few days a pretty busy, waiting for a baby to pop. But I will see if I can post pics, also might wait until I put new lug nuts on the rusty original ones look crappy. The product I used was plasticoat bed liner in aspray bomb. Works great did all four rims with one can.
Dustin
Dustin
- Firesong
Deli is in the shop getting a 2.5" exhaust put on (straight)... should sound
throaty when it comes out.
FS
FS
- Firesong
It no longer has the 'cricket' sound... more like a
lion with a hambone
FS
lion with a hambone
FS
Installed a VW Transporter swivel seat in our Chamonix. Kids love it.
Fuel filter, cleaned bus bar, fixed the broken hold down for the batteries.
In the process I broke the hose barb off the top of the radiator (the one that goes to the overflow bottle). Drilled and tapped for 1/8 NPT, installed new barb, waiting to see if pipe thread/teflon tape/JB weld combo will hold pressure/temperature.
- lettereleven
- Vehicle: L400 Super Exceed
Dismantled the wiper spray hosing. Unplugged the gick from on of the little valves, felt very proud of myself.
That was until I discovered that it isn't fixed. Squirts about 2 inches, which I suppose is still and improvement from the drizzle.
I did manage to fix the parking brake however. So not a total wasted session in the rain.
- DelicaMark
- Vehicle: L400
Found inspiration from another green (maybe it was blue) on grey van I saw on Saturday. They had painted their intercooler intake on the hood to match the grey. I had been meaning to do this since I bought the van last year. Found a pretty good match metallic paint and....
It actually matches better than this angle looks. Then I got crazy and replaced the trim around my wheels flares. One of the old rubber ones had actually blown off on the highway a couple of weeks ago...well about 4 inches had blown off then I stopped and removed it. I used door edge trim that has a little glue inside. Removed the flares and used a hair dryer to mold the edge trim. Worked great! I really want to paint my rims...any thoughts on that. Seems the old internet has all kinds of successful stories of it. Prep, prep, prep and a little more prep seems to be the key to a good outcome.
-Mark
-Mark
For painting alloys... Sand, clean, spray primer, paint. I used red rust-check paint and mat black rim specific paint. They have been great, the only chips are from having the wheels balanced. I did the whipsaw trail without a scratch (on the rims at least). Total cost was $7.
- DelicaMark
- Vehicle: L400
Thanks nxski. That is kind of what I have been seeing. I also saw the rim specific paint, which is what got me looking more seriously into doing it.
Did you sand off all of the clear coat on the rims? I assume there is some level of clear coat. I guess you just need to get them scuffed up enough to accept the primer.
-Mark
-Mark
Brand? Colour? Source? You're not the only one with peeling paint on an intercooler inlet you know...DelicaMark wrote: Found a pretty good match metallic paint and....
And in an effort to move forward and create a reciprocal exchange of mutual benefit...I really want to paint my rims...any thoughts on that. Seems the old internet has all kinds of successful stories of it. Prep, prep, prep and a little more prep seems to be the key to a good outcome.
-Mark
I've done all kinds of wheel painting. My favorite outcome has been using Metalcast Ground Coat. It's basically silver sparkles, but it replicates cast aluminium pretty well.
Metalcast on left, polished AL on right:
More Metalcast:
My rims were very worn so it was more a question of removing dirt first than removing the clearcoat. I sanded them until there were scratch marks everywhere though.
- Vehicle: L400
Everything about the front end of your L400 looks fantastic. Two thumbs up!DelicaMark wrote:
- DelicaMark
- Vehicle: L400
Thanks! I have some other changes coming in the next few months too.psilosin wrote:Everything about the front end of your L400 looks fantastic. Two thumbs up!
I actually used for better or worse a wheel paint. It was the best match I could find at Lordco, which was my only stop for paint. I figured if for some reason it really didn't work on the plastic I would just sand it off and try and different type of paint. -MarkDelicaMark wrote:Brand? Colour? Source? You're not the only one with peeling paint on an intercooler inlet you know...
Worked out well. No shaking. Swivel bearing is tight.jfarsang wrote:Installed a VW Transporter swivel seat in our Chamonix. Kids love it.
- 6813470680_f74f851f32_z.jpg (173.69 KiB) Viewed 5881 times
- 6813471158_49305ed651_z.jpg (197.63 KiB) Viewed 5881 times
- 6959582377_71a82b9da4_z.jpg (177.24 KiB) Viewed 5881 times
- doodah
- Vehicle: 96 Delica L400 Exceed
sweet... looks great and I want one!
