Pyro and Boost gauge - what kind and where did you mount 'em
Mr. Flibble
Re: Pyro and Boost gauge - what kind and where did you mount
Post by Mr. Flibble »
RichD wrote:Question for the forum: what would you use the temperature gauge for: engine oil, water or trans oil temp?
It occurred to me that I could order two more temperature sender probes and put them on a three-way two-pole switch.
I was just browsing the forum, trying to figure out how to rig an AT Temp gauge without taking up too much room as I will (FINALLY) be installing my Glow-Shift Gauge. I was at a loss for how to fit one more gauge in there (I am using a RHD pillar pod, it will contain 5 readouts) and I stumbled across your suggestion.
It is brilliant! It is exactly what I will be doing. Lets me monitor coolant or AT at the flick of a switch! Now maybe to figure out something with an indicator to show which is which: AT or Water.
Erebus
Vehicle: 1992 Super Exceed
Post by Erebus »
Mr. Flibble wrote: It is brilliant! It is exactly what I will be doing. Lets me monitor coolant or AT at the flick of a switch! Now maybe to figure out something with an indicator to show which is which: AT or Water.
Double pole, double throw switch; one pole to switch the gauge, the other pole to illuminate two different coloured LEDs to let you know which "side" is on.
Mr. Flibble
Now if I can just find some small lights labeled "AT" and "Water".....
fredt
Vehicle: l400
Post by fredt »
quote="Mr. Flibble"]
It is brilliant! It is exactly what I will be doing. Lets me monitor coolant or AT at the flick of a switch! Now maybe to figure out something with an indicator to show which is which: AT or Water.[/quote]
blue for water and red for AT fluid or brown if you screw up the tranny!
LeeHammy
Post by LeeHammy »
I have a spare Auto Meter Boost gauge that I need to get rid of. Its the larger size at 2" 5/8ths. New around $75.. its still new in box for $50.
i like cheese
stever1000
Vehicle: 94 L400 SuperExceed
Post by stever1000 »
Where can I get an EGR plate drilled/tapped for pyro probe? Oddball offroad's site is no longer working
Thanks!!
RickJ
Vehicle: 1994 L400 SE
Post by RickJ »
You can easily make it yourself. I used a piece of 1/4" plate steel I had laying around for the exhaust manifold side. I traced out a paper template of the shape and bolt hole pattern and glued it to the steel as a drill template. I was later able to drill and tap a center hole to mount the compression fitting for the thermocouple itself.
I did the same thing for the intake manifold to plank off the cold side of the EGR valve using a piece of 1/4" aluminum plate..
islander20
Vehicle: 1994 L400 LWB
Post by islander20 »
Wish I had the tools to do that...i've been trying to find a tapped blanking plate as well.
I spent $100 and had a guy seal weld a 1/4" piece of aluminium onto where the EGR goes and he also fabricated a losange shape steel plate to fit over the exhaust manifold end of the EGR. One thing you MUST consider if you are doing anything like this is "galvanic reaction". Steel plate against aluminium does not work, the aluminium will start to erode because of the galvanic reaction.
There are a couple of members that have manufactured EGR blanking kits, I'd suggest going to either of the two site search engines and search "EGR blanking kits" and see what you turn up. I also know that CVI installs these kits, maybe give them a call?
Tojo
Post by Tojo »
Bought mine off of ebay: http://www.ebay.co.uk/itm/EGR-REMOVAL-K ... 259a15b3e2
This seller will also drill and tap a hole upon request.
For my L400 I bought from this seller because it came with gaskets: http://www.ebay.co.uk/itm/EGR-BLANKING- ... 20e54d1dc6
If you're looking for a 1/8"-27 NPT tapped hole, then I can drill it for you.
stever1000
I also dont have the tools to fab one myself and i have searched and nothing recent has been posted
I will call CVI and ask there
Tojo wrote:Bought mine off of ebay: http://www.ebay.co.uk/itm/EGR-REMOVAL-K ... 259a15b3e2
Excellent, i will contact the eBay seller
stever1000
I contacted CVI and Butch said they are out of the kits.
I also contacted the UK sellers for more information about drilling and tapping the hole for the EGT probe
I'll post back with details once I know more
Another option to check out is Dennis Lambert. See if he can help you.
stever1000
FalcoColumbarius wrote:Another option to check out is Dennis Lambert. See if he can help you.
Thanks Falco!
I've been in contact and he has the regular plates. Waiting to hear back about the drilled and tapped plate.
Thanks Falco!
Well, I'm not particularly smart and my wisdom is limited but sometimes I get a flash in the pan, as it were. Please pass on my regards to Dennis... smiles.
