Clicking while driving
daveyboy70
Post by daveyboy70 » Sun Nov 09, 2008 5:10 pm
Well I have done a search and come up with some stuff but no diffinitive answers......so I am canvassing for some help!
On the way home from my daughters swimming lessons (not that this matters) the glow plug relay (or whatever makes the clicking sound at starting) started going wild, clicking constantly. I was 3 minutes from home so brought it there. I have read that it could be the ECU, a relay or something.
Has anyone fixed this problem? as I have read there are a few out there that have had this issue
Thanks for the help!
Dave (3 weeks into ownership)
Re: Clicking while driving
Post by jessef » Sun Nov 09, 2008 6:00 pm
3 weeks into ownership. Did you buy it private or from a dealer ? If from a dealer, then it should be under warranty.
If not, then there are a few things to check.
The voltage at the glow plugs to make sure they are working.
If the ECU (glow plug control unit) is not working properly, most electronics shops will repair it for around $80-150.
The parts inside are common.
daveyboy70
Post by daveyboy70 » Sun Nov 09, 2008 6:05 pm
Yep 3 weeks, but it is OK I got it from a dealer and it is under warranty Mardy is going to have a look at it tomorrow, but I am just trying to learn something as I go. This is my first diesel and am unfamiliar with working on them so the more knowledge I get about trouble shooting the better. Thanks for the help, I love this forum.
Dave
Vehicle: 2013 Toyota Tacoma
Post by mararmeisto » Sun Nov 09, 2008 7:13 pm
What is your engine temperature indication? If it is erratic, then the two-wire temperature sensor is probably at fault. One side of that sensor goes to the dashboard, the other side goes to the ECU. If the sensor is faulty, the ECU thinks the engine is cold, fires the relays and that could be the clicking you're hearing. This is what happened to Moon Machine recently.
Post by jessef » Sun Nov 09, 2008 9:02 pm
Welcome Dave. :M
Mardy (Amazing Auto) takes really good care of his clients. Top dealer/service IMO.
One of my Pajero's and the last Delica I had, had the same symptoms. It turned out to be some faulty capacitors on the ECU circuit board. Both were fixed without any issues.
Enjoy your Delica !
daveyboy70
Post by daveyboy70 » Sun Nov 09, 2008 9:56 pm
Thanks for the piece of mind, I dropped the beast off at Mardi's shop just now and he is going to troubleshoot tomorrow. He mentioned the ECU when I spoke to him today, so sounds like he already has the same thinking as what you mentioned.......I just hope all is well. I have put 100 km per day driving to and from work since buying my Delica and they have been the most enjoyable miles I have ever put on.
daveyboy70
Post by daveyboy70 » Tue Nov 11, 2008 3:27 pm
It turned out to be ECU which Mardi swapped out with one he had in another bus, he left mine with me to get it redone at a local shop which he is going to provide me tomorrow.
L300Foca
Vehicle: Mitshubishi L300 2.5 TD GLX
Post by L300Foca » Fri Nov 12, 2010 1:26 am
daveyboy70 wrote:It turned out to be ECU which Mardi swapped out with one he had in another bus, he left mine with me to get it redone at a local shop which he is going to provide me tomorrow.
I have same problem :)
Will u please upload picture of that ECU?
Or: on this picture:
http://www.japancars.ru/cat/mitsubishi/ ... =16&bg=310
14622PB RESISTOR,GLOW PLUG CONTROL ?
or
14616QH RELAY,GLOW PLUG CONTROL ?
FollowMe
after oil
Post by after oil » Sat Nov 13, 2010 5:03 pm
or
the ECU or Electronic Control Unit is in the pillar behind the drivers seat. take off the plastic cover over the seat belt, unbolt the seat belt, take off the other plastic behind, and you will see the ECU. it is a gold or silver box.
dfnder
Vehicle: '91 Exceed
Post by dfnder » Sat Nov 13, 2010 7:54 pm
Mine was doing a lot of clicking at one point as well, turned out to be the temperature sensor that was on top of the motor.
CVI
Post by CVI » Mon Nov 15, 2010 10:21 am
mararmeisto wrote:What is your engine temperature indication? If it is erratic, then the two-wire temperature sensor is probably at fault. One side of that sensor goes to the dashboard, the other side goes to the ECU. If the sensor is faulty, the ECU thinks the engine is cold, fires the relays and that could be the clicking you're hearing. This is what happened to Moon Machine recently.
I would go with maramiesto 100%. Check this sensor first. Thru time, the internal resistance doesnt respond as quick until it conks out completely. The ECU - if faulty - will not trigger the relays...hence no clicking sound to begin with. Clicking sound is your relays actuating.
Good luck.
CVI Automotive
JDM & Imported Vehicles Specialist
104-2353 Peardonville Road Abbotsford BC V2T 6J7
Phone: 604.710.7000 email: ati@atigroup.com.ph
Web: cviauto.com
