Another headlight post
javabob
Vehicle: 1991 Exceed (P35W)
Post by javabob » Thu Mar 30, 2017 9:04 pm
I think I've read every post I could find on getting headlights for North America and e codes, but I'm still or maybe even more confused.
Is there any way to point the beam to the right? I've read that the adjusting screws won't do the trick because the lenses are made for LH traffic.
Are there replacement lenses? Do beam benders really work? I can only see about 20 feet in front of me but can see all the oncoming traffic really well. I know there are mooses ready to attack on the right side of the road but I can't see them :-D If I was in my 20s it wouldn't be a problem but my older non-flexible eyes are struggling.
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.
tomaboyd
Vehicle: 1991 Delica Exceed
Post by tomaboyd » Fri Mar 31, 2017 8:07 am
I felt your pain. When I got my Delica the lights were horrible. Poor output and pointed way right.
The short answer is no. There is no way to adjust any light available to match the North American pattern. Do a quick Google search on beam patterns and you will find images that help you understand.
My ecodes were over 10 years old so I did two things. Bought new ones and then upgraded the bulbs to high outputs. Osram Nightbreaker I believe.
Made a huge difference. If you already have ecodes do the bulbs first. If your need to adjust the beam do so gingerly. When I got my old ones off I found the adjuster s were in bad shape. I did take the time to take them all apart and fix them. So that is an option for you
Good luck
javabob
Post by javabob » Fri Mar 31, 2017 8:23 am
tomaboyd wrote:I felt your pain. When I got my Delica the lights were horrible. Poor output and pointed way right.
Good luck
I don't have Ecodes, could you point me in the right direction to find some? All my google-fu is failing me.
lrp374
Vehicle: 91 Super Exceed
Post by lrp374 » Fri Mar 31, 2017 10:38 am
These may help and they're even on your side of the border!!
viewtopic.php?f=1&t=17968
tomaboyd
Post by tomaboyd » Sat Apr 01, 2017 8:45 am
Unfortunately the add was mine. I got tired of them sitting in the basement and dropped them off at Rising Sun last week.
You can get these, or new ones, from Steven at Rising Sun. japancarexpress@gmail.com
If you want my old ones tell him you want the ones Tom Boyd just dropped off. If you want new ones, he will have them. Be warned, new ones are not cheap, but I thought worth the $
