Hey Guys,
I want to lift my 1999 pajero (chassis # V78W-0004559) 2" to accommodate 33" tire. I bought a set of coil spacers but the springs are slipping off the spacers. (no groove in spacer and a little thin). Suspension guys here in town suggested i just buy longer springs. Does anyone know where i can get springs 2" longer for my pajero or compatible? Thanks so much for any help.
Regards,
Jeremy.
Rear Coil Spring Compatability
- Vehicle: Delica L400 Exceed
I think Old Man Emu out of Australia makes them. Probably alot of cash to bring in though. I know there are custom spring shops out there too that will design them to your specs. A set of custom progressives would be awesome!
Have you tried fitting your '99 with 33's? I can fit 33x10.5 on stock offset with no rubbing at full articulation front and rear. 33x12.5x15 I needed to trim the plastic fenders etc, which you wont be able to do with your blister fenders.
Maybe post up what spacers you bought so guys know what not to buy. Thanks!
Sent from my H3223 using Tapatalk
