JB500 camper body on L300 truck chassis build
begoodtothemalways
Vehicle: 1993 Delica L300
Post by begoodtothemalways »
Wow, this is such a cool machine. I just purchased an L300 and am slowly working away at the conversion. Pretty cool to see what you can do with all the extra space.
Amanda
Ace91
Vehicle: 1998 Mitsubishi Delica Chamonix
Post by Ace91 »
Nice setup.
Thanks ! It's making its way across Canada now to the maritimes.
Ralph in Winnipeg
Vehicle: 94 Strada
Post by Ralph in Winnipeg »
Now that's a drive! If you need anything in the river city, let me know!
Ralph in Winnipeg
Nulla
Vehicle: Delica JB500
Post by Nulla »
Thank you for sharing, I have been searching for a jb500 thread. Mine arrive in about 2 weeks it is now at the port waiting to clear custom. It is 1994 4D56 Turbo diesel with manual transmission, 43k miles. It is interesting that you put a 32" diameter tires on it without lifting. I am curious of the cruising speed with the 32" tires. I know you mention on your thread that it handles very well.
Did you change the timing belt, water pump, seals, tensioners etc... if you did can you pls share with me your sources.
Thank you again for sharing.
BCDelica
Vehicle: WVO Powered Tuk Tuk
Post by BCDelica »
jessef wrote: Mon Oct 02, 2017 5:56 pm It will be pretty neat to work on an L300 with a truck frame. It's been a while. Wonder how many old timers are still on here ? :-D
Older post, do you still have you Delica motorhome Jesse?
Does being a Grandpa of 3 make me an old timer? Oh, I still have 2 JDM's at home, my Surf I've had since the end of Feburary this year has seen a lot of abuse due to the Covid.
Kevin
Image Call me BCDelica-less
Return to “Member Rides”
