Coolant question? What is the correct coolant for the 4m40?
Issues relating to the purchasing, importing, and inspection of JDM vehicles in Canada
Antigonish medic
Vehicle: L 400 SWB 1994
Post by Antigonish medic »
Hello,
I have been doing a ton of searching and have yet to find a definitive answer. This may have been posted already, but I could not find it. What coolant is correct for a 4m40 motor. I have just bought a 95 pajero and it was in need of a flush, I had a shop do it and they put it dexcool, which I had asked them not to do.
Will dexcool cause damage to my system?
After doing a ton of searching, I am leaning to getting my coolant from a local John Deere shop, green and for diesel motors. That is what they use in the 4m40 which they service in local tractors. I live way out on the east coast, so no local delica shop to check in with. I have not been driving that much since the flush (4days) so I am more concerned with long term damage, and want to know what the experience here has found.
My delica, which is currently off the road with body damage, has green coolant, and the pajero had yellow in it when I bought it. Thanks, Adam.
CREGAN
Re: Coolant question? What is the correct coolant for the 4m
Post by CREGAN »
I have used Mopar diesel antifreeze. Mardy put it in when I got it and I put it in last year when I flushed it. Probably the same as the John Deere stuff, just easier to get.
Craig
1994delicaman
Vehicle: KTM
Post by 1994delicaman »
Antigonish medic wrote:Will dexcool cause damage to my system?
Why would you think to put garbage in your cooling system, have you read how many problems dexcool has??
2006 smart car diesel CDI
2011 KTM 990 Adventure
2015 Mercedes GLK250 Bluetec
2018 KTM Superduke 1290 R
CREGAN
Post by CREGAN »
He said "they" did. Not him.
Craig
Antigonish medic
I went back to the shop and checked, it was not dexcool as I had thought, but a long life coolant, still orange in colour. That is why I assumed dexcool. The shop uses it in gas and diesel with aluminum or copper rads.
The guys say that they have never had an issue, but I Still don't trust it. So I will flush the system again, when I can find a few spare minutes and it as we are about to have our first child. It is also freaking cold outside.
From what I am gathering, a diesel specific coolant that is not dexcool will suffice. Thanks. Adam.
MardyDelica
Post by MardyDelica »
u just used regular green antifreeze I used green from Chrysler they used in cummins.
very compatible no issue at all to any diesel engine for the past 9 years.
the orange one they say ok for diesel is for the newer diesel.
as the newer diesel has diff material on the cylinder head gasket while delica has old type of cylinder head gasket.
if you put the orange one its very strong chemical on it , eventually damage and eat your existing cylinder head gasket.
cheers
macro
Vehicle: L400 "The Invader"
Post by macro »
Just for some clarification on this. I've used some of the red "long-life" antifreeze to top up my coolant. Very very little and not very often. Like, less than a litre over the course of the last couple years. Is this something I need to deal with?
Return to “Import, Inspection & Registration”
