So here's what I bought from PlantDrive:
So far I've got the VergTherm, Pollack Valve and VegMax tagged on.
VegTherm
VegMax installed behind passenger size wheel well
The red circles are the bolts holding the VegMax on, the yellow circle is a hole drilled when I should have been measuring twice.
Pollack Valve bolted to a hole that already existed:
Right now it is only held on with one bolt so I might have to beef up the mounting, but the valve itself is pretty light and does not seem to need the 2 bolts. This might change when I attach the diesel and VO hosing.
Next Step: Wiring
I've got a few questions for Josh, Kevin and/or anyone else that has installed a similar kit:
- Where did you run the wiring for the toggle switch? Did it involve taking apart most of your dash? I'm still working on extracting my cigarette lighter socket, but it's tough getting the brass holding ring off.
When you added the Tees to your coolant and fuel lines what was the procedure you used, and btw do you have a good picture identifying where and which hoses I should be cutting? I'm planning on using a couple of locking pliers to isolate a section of fuel/coolant line, cut the line, add the tee and release the pliers once the lines are all connected. Sounds easy, but I'm sure I'll mess it up.
Do you have to manually prime the engine after you've spliced in all the tees and connected the Pollack valve to get all the air out of the system? If so, how do you do that?
