How to remove an L300 door panel.
- Mbryant
- Vehicle: White 93 Exceed Crystal lite roof
How to remove a door panel. I have more than seven pictures so they are divided over two postings because I read that we can/should only add a max of seven photos to a post.
- one.jpg (182.5 KiB) Viewed 11923 times
- two.jpg (156.98 KiB) Viewed 11923 times
- three.jpg (135.83 KiB) Viewed 11923 times
- four.jpg (144.92 KiB) Viewed 11923 times
- five.jpg (139.78 KiB) Viewed 11923 times
- six.jpg (120.87 KiB) Viewed 11923 times
- Mbryant
How to remove a door panel (part two)
Here is the second part of how to remove a door panel.
On step seven I use a large flat screw driver but there is a specific tool that can be purchased to do the job. The screwdriver worked fine for me.
On step eight I took apart the door light from the back but I had read in another post that an alternative is to remove the light cover and unscrew the light fixture from the panel.
On step nine I tried to put an arrow to the section I was describing but my computer skills maxed out. So I am describing the area where the door panel (gray) meets the plastic piece (black) in the window corner.
- seven.JPG (269.75 KiB) Viewed 11919 times
- eight.jpg (163.64 KiB) Viewed 11919 times
- nine.JPG (260.49 KiB) Viewed 11919 times
- ten.jpg (164.58 KiB) Viewed 11919 times
