Clutch Kit/flywheel assy for L300 5 spd owners
Rising Sun Auto Import
We are selling clutch kit for Delica L300 at $399.
It comes with clutch disc, clutch cover, pilot bearing and clutch release bearing.
Most Delica coming into Canada have never been replaced with clutch kit in Japan as it has relatively low mileage ,
so we may need to replace them sooner or later. :-)
If interested, call me 778-995-2459 or e-mail me japancarexpress@gmail.com.
Steven
Last edited by Rising Sun Auto Import on Fri Jun 17, 2011 12:35 pm, edited 6 times in total.
Slimdog
Vehicle: 2000 L300 LWB
Re: Clutch Kit for 5 spd owners
Post by Slimdog »
On average how many kms does the L300 stock clutch get?
Slimdog wrote:On average how many kms does the L300 stock clutch get?
Depending on the driving habit/skill and where you or previous japanese owners mainly operate a car ( hwy or city ), it goes between 80K-140K. :-D :M
Slimdog
Post by Slimdog »
Thanks for the reply. I guess mine has been done at least once.
Is there a way to check and see how much of the disc is left?
Vehicle: -
Post by fexlboi »
Do you also have a pilot bearing and master-slave cylinder?
fexlboi wrote:Do you also have a pilot bearing and master-slave cylinder?
We have a pilot bearing ( Hyundai OEM ) as a clutch kit package, but currently no stock for master-slave cylinder.
If you need master-slave cylinder, I can get them in 5 days. :M
Steven
We have 10 set of new clutch kit in stock from Hyundai Korea for L300.
Price ; $399
Also installation service is available at $400.
If you need machining flywheel ( $45 ) and replacing rear main seal ( $50 ) , we charge only parts ( $95 ) without additional labour added.
Oil separator , oil seal case and oil seal case gasket will be provided free of charge when you get this service.
We also have new Hyundai flywheel ( $250 ) in stock.
Ask for details.
Steven 778-995-2459
1 (1).JPG (112.19 KiB) Viewed 2875 times
Re: Clutch Kit for L300 5 spd owners
More pics for flywheel, oil seal case, gasket, oil seal separator, etc.
Steven
flywheel_4D56 (2).JPG (113.8 KiB) Viewed 2834 times
oil seal separator.JPG (87.13 KiB) Viewed 2834 times
oil seal case etc (2).JPG (96.68 KiB) Viewed 2834 times
oil seal case etc (5).JPG (58.8 KiB) Viewed 2834 times
oil seal case etc.JPG (83 KiB) Viewed 2834 times
