We are selling clutch kit for Delica L300 at $399.
It comes with clutch disc, clutch cover, pilot bearing and clutch release bearing.
Most Delica coming into Canada have never been replaced with clutch kit in Japan as it has relatively low mileage ,
so we may need to replace them sooner or later.
fexlboi wrote:Do you also have a pilot bearing and master-slave cylinder?
We have a pilot bearing ( Hyundai OEM ) as a clutch kit package, but currently no stock for master-slave cylinder.
If you need master-slave cylinder, I can get them in 5 days.
Steven
Rising Sun Auto Import Inc. **Ultimate Home of Delica in North America**
Delica Injection Pump Rebuilt, Cold Start & Engine/Turbo Work Specialist Unlimited source for new & used parts
We have 10 set of new clutch kit in stock from Hyundai Korea for L300.
Price ; $399
Also installation service is available at $400.
If you need machining flywheel ( $45 ) and replacing rear main seal ( $50 ) , we charge only parts ( $95 ) without additional labour added.
Oil separator , oil seal case and oil seal case gasket will be provided free of charge when you get this service.
We also have new Hyundai flywheel ( $250 ) in stock.
Ask for details.
Steven 778-995-2459
1 (1).JPG (112.19 KiB) Viewed 2881 times
