L400 new parts in stock
Rising Sun Auto Import
We have some new parts( spacegear ) for sale, which are from Mitsubishi Osaka.
Contact us for more details.
1. Timing Gear Case $300
2. Front Crankshaft Oil Slinger $15
3. Timing Case Oil Seal $45
4. Crankshaft Pulley $350
5. Crankshaft Key $8
6. Rear Crankshaft Oil Seal $65
7. Power Steering Seal Kit $250
8: 4M40 Oil Pressure switch $55
Steven
Last edited by Rising Sun Auto Import on Tue Jul 26, 2011 1:59 pm, edited 5 times in total.
Re: L400 parts for sale
Here are some pics for parts mentioned above.
Steven
part 2 008.JPG (115.21 KiB) Viewed 1858 times
part 2 004.JPG (93.94 KiB) Viewed 1858 times
part 2 006.JPG (65.1 KiB) Viewed 1858 times
part 2 005.JPG (89.36 KiB) Viewed 1858 times
part 2 003.JPG (73.85 KiB) Viewed 1858 times
part 2 002.JPG (83.73 KiB) Viewed 1858 times
Re: L400 new parts for sale
More parts for L400
1. coolant expansion bottle ( Mitsubishi original ) ; $165
2. 4WD vacuum solenoid ; $199
3. 4wd front axle sensor to fix 4wd operation; $150
4. slidingdoor handle ; $180
5. cup holder ; $120
6. spacegear center console ( brand new, Mitsubishi ) ; $250
7. glow plug relay_new ( 4M40 ) ; $50
Steven 778-995-2459
delica part 003.JPG (48.08 KiB) Viewed 1736 times
dec20 011.JPG (84.49 KiB) Viewed 1736 times
part 002.JPG (81.56 KiB) Viewed 1736 times
Last edited by Rising Sun Auto Import on Sun Jun 12, 2011 8:37 pm, edited 1 time in total.
Re: L400 new parts in stock
More in stock.
1. set of rear rotors ; $150 ( $85 each )
2. front brake pads ; from $65
3. rear brake pads ; from $75
4. front rotor ; from $90 with core return
5. rear rotor ; from $95 with core return
6. rear brake hose ; $15
7. set of glow plugs ; $140 ( $45 each )
8. injector with heatshields/gasket ; $110
9. air filter ; $27
10. fuel filter ; $20
11. oil filter( Sakura ) ; $20 all sold out. more in late August
12. front stabilizer bar bushing ; $13
13. rear stabilizer bar bushing ; $10
14. radiator hose, upper ; $40
15. radiator hose, lower ; $50
16. Rear differential case bearing , Rear differential Drive Pinion /front side bearing,
Rear differential Drive Pinion / rear side bearing ; from $70
17. Rear differential Drive Pinion oil seal ; $45
18. Front differential drive pinion oil seal ; $45
19. Front differential drive pinion / rear bearing , Front differential drive pinion /front bearing ; from $75
20. Front differential side bearing ; $75
21. Front differential side oil seal ; $45
22. valve cover gasket/bolt seal/front and rear end seal ; $65
23. cylinder head/bare ; $700 ( special price )
24. complete cylinder head ; $1,200
25. head gasket ; $160
26. alternator : $280 with core return
27. starter ; $250 with core return
28. fuel filter assy ; $90
29. belt set ; $70
30. IP main seal ; $30
31. EGR blanking plates ; $20
32. E-code headlight lenz ; $390
33. E-code headlight assy ; $500
34. manual locking hub ; $250
35. water pump with gasket ; $110
36. thermostat with gasket ; $35
37. Lower ball joint ; $75 each
38. upper ball joint ; $55 each
39. outer tie rod ; $45 each
40. inner tie rod ; $75 each
41. front stabilizer link ; $45 each
42. rear stabilizer link ; $55 each
43. front rotor set ; $160 ( $95 each )
44. radiator ; $250
45. cooling fan ; $80
We continue to stock more parts as possible as we can to serve your maintenance works.
For part (new or used) inquiry, pls send email to japancarexpress@gmail.com.
We will reply you asap and we offer delivery service under certain condition in Vancouver area. 8-)
Steven
