We have some new parts( spacegear ) for sale, which are from Mitsubishi Osaka.
Contact us for more details.
1. Timing Gear Case $300
2. Front Crankshaft Oil Slinger $15
3. Timing Case Oil Seal $45
4. Crankshaft Pulley $350
5. Crankshaft Key $8
6. Rear Crankshaft Oil Seal $65
7. Power Steering Seal Kit $250
8: 4M40 Oil Pressure switch $55
Steven
L400 new parts in stock
- Rising Sun Auto Import
Last edited by Rising Sun Auto Import on Tue Jul 26, 2011 1:59 pm, edited 5 times in total.
Re: L400 parts for sale
Here are some pics for parts mentioned above.
Steven
Steven
- part 2 008.JPG (115.21 KiB) Viewed 1859 times
- part 2 004.JPG (93.94 KiB) Viewed 1859 times
- part 2 006.JPG (65.1 KiB) Viewed 1859 times
- part 2 005.JPG (89.36 KiB) Viewed 1859 times
- part 2 003.JPG (73.85 KiB) Viewed 1859 times
- part 2 002.JPG (83.73 KiB) Viewed 1859 times
Re: L400 new parts for sale
More parts for L400
1. coolant expansion bottle ( Mitsubishi original ) ; $165
2. 4WD vacuum solenoid ; $199
3. 4wd front axle sensor to fix 4wd operation; $150
4. slidingdoor handle ; $180
5. cup holder ; $120
6. spacegear center console ( brand new, Mitsubishi ) ; $250
7. glow plug relay_new ( 4M40 ) ; $50
Steven 778-995-2459
Steven 778-995-2459
- delica part 003.JPG (48.08 KiB) Viewed 1737 times
- 117.JPG (178.22 KiB) Viewed 1737 times
- dec20 011.JPG (84.49 KiB) Viewed 1737 times
- 4wdfrontaxle_sensor_L400.JPG (170.93 KiB) Viewed 1737 times
- part 002.JPG (81.56 KiB) Viewed 1737 times
- L400centerconsole.jpg (73.01 KiB) Viewed 1737 times
Last edited by Rising Sun Auto Import on Sun Jun 12, 2011 8:37 pm, edited 1 time in total.
Re: L400 new parts in stock
More in stock.
1. set of rear rotors ; $150 ( $85 each )
2. front brake pads ; from $65
3. rear brake pads ; from $75
4. front rotor ; from $90 with core return
5. rear rotor ; from $95 with core return
6. rear brake hose ; $15
7. set of glow plugs ; $140 ( $45 each )
8. injector with heatshields/gasket ; $110
9. air filter ; $27
10. fuel filter ; $20
11. oil filter( Sakura ) ; $20 all sold out. more in late August
12. front stabilizer bar bushing ; $13
13. rear stabilizer bar bushing ; $10
14. radiator hose, upper ; $40
15. radiator hose, lower ; $50
16. Rear differential case bearing , Rear differential Drive Pinion /front side bearing,
Rear differential Drive Pinion / rear side bearing ; from $70
17. Rear differential Drive Pinion oil seal ; $45
18. Front differential drive pinion oil seal ; $45
19. Front differential drive pinion / rear bearing , Front differential drive pinion /front bearing ; from $75
20. Front differential side bearing ; $75
21. Front differential side oil seal ; $45
22. valve cover gasket/bolt seal/front and rear end seal ; $65
23. cylinder head/bare ; $700 ( special price )
24. complete cylinder head ; $1,200
25. head gasket ; $160
26. alternator : $280 with core return
27. starter ; $250 with core return
28. fuel filter assy ; $90
29. belt set ; $70
30. IP main seal ; $30
31. EGR blanking plates ; $20
32. E-code headlight lenz ; $390
33. E-code headlight assy ; $500
34. manual locking hub ; $250
35. water pump with gasket ; $110
36. thermostat with gasket ; $35
37. Lower ball joint ; $75 each
38. upper ball joint ; $55 each
39. outer tie rod ; $45 each
40. inner tie rod ; $75 each
41. front stabilizer link ; $45 each
42. rear stabilizer link ; $55 each
43. front rotor set ; $160 ( $95 each )
44. radiator ; $250
45. cooling fan ; $80
We continue to stock more parts as possible as we can to serve your maintenance works.
For part (new or used) inquiry, pls send email to japancarexpress@gmail.com.
We will reply you asap and we offer delivery service under certain condition in Vancouver area.
Steven
9. air filter ; $27
29. belt set ; $70
44. radiator ; $250
Steven
