Ok, the head has been replaced. I had a look in this string, but can't seem to find any refernce on how to find top dead center to continue the process.
THX in advance.
Arnold
Top Dead Center pls
- Super Exceeded
- Vehicle: 1993 L300S
Re: Top Dead Center pls
Should be mark on the crank pulley, watch the valves to see when both valves are closed on the cylinder you want top dead center on.
Waiting to hear it running!
- Super Exceeded
THX assuming timing is based on the front cylinder!
- Vehicle: exceed
Turn it over with a wrench and make sure there is no binding. If you have the cam and rockers assembled and no cam belt fitted some valves will be opened and will collide with the pistons as they move.
I forgot the belt was off....that is funny since it was the start of the problem!
- Lapprentis
- Vehicle: Delica L300 StarWagon 1990
Top Dead Center pls
So can someone confirm that the TDC (Top Dead Center) position is confirm by the front of the engine marks on the Pulleys ? For Injection Pump Timing Purposes.
Thanks !
Lapprentis
Thanks !
Lapprentis
Top Dead Center pls
Look in the engine manual, 11B: http://www.delica.ca/manuals/L-300%20Ma ... engine.pdfLapprentis wrote:So can someone confirm that the TDC (Top Dead Center) position is confirm by the front of the engine marks on the Pulleys ? For Injection Pump Timing Purposes.
Thanks !
Lapprentis
