Top Dead Center pls
Super Exceeded
Vehicle: 1993 L300S
Top Dead Center pls
Post by Super Exceeded »
Ok, the head has been replaced. I had a look in this string, but can't seem to find any refernce on how to find top dead center to continue the process.
THX in advance.
Arnold
thedjjack
Vehicle: 1989 L300 HITOP!!
Re: Top Dead Center pls
Post by thedjjack »
Should be mark on the crank pulley, watch the valves to see when both valves are closed on the cylinder you want top dead center on.
Waiting to hear it running!
Super Exceeded
Vehicle: 1993 L300S
THX assuming timing is based on the front cylinder!
jelbon
Vehicle: exceed
Post by jelbon »
Turn it over with a wrench and make sure there is no binding. If you have the cam and rockers assembled and no cam belt fitted some valves will be opened and will collide with the pistons as they move.
thedjjack
Post by thedjjack »
I forgot the belt was off....that is funny since it was the start of the problem!
Lapprentis
Top Dead Center pls
Post by Lapprentis »
So can someone confirm that the TDC (Top Dead Center) position is confirm by the front of the engine marks on the Pulleys ? For Injection Pump Timing Purposes.
Thanks !
Lapprentis :M
Top Dead Center pls
Lapprentis wrote:So can someone confirm that the TDC (Top Dead Center) position is confirm by the front of the engine marks on the Pulleys ? For Injection Pump Timing Purposes.
Thanks !
Lapprentis :M
Look in the engine manual, 11B: http://www.delica.ca/manuals/L-300%20Ma ... engine.pdf
