As a matter of fact your van does not have OBD2; neither does mine or any other L400 in Canada. Not yet.northriver wrote:I've also thought about interfacing to the OBD-II plug of the van but not sure how useful this information is.
I have not checked ... but from reading on the UK Delica website I was left with the impression that it was there ... somebody on that site indicated that the OBD-II plug was provided starting in the 1994 model year ... has anybody checked to see if there is one at the base of the steering column after some of the panels are removed?Profister wrote: As a matter of fact your van does not have OBD2; neither does mine or any other L400 in Canada. Not yet.
It was around 0 C ... you are probably right about summer vs. winter.Kuan wrote:What was the temperature out when you shut down the van? Probably safe to do in the heat of summer where the viscosity of the oil will stay low.
Have you figured out how long of a purge you need?
Have you gone as far as identifying a thermocouple? Or a pressure gauge?Kuan wrote:I've been looking into doing an arduino based controller for a while now as I have a programming background. It looks like it would be fairly straight forward as the logic is pretty simple. I was planning on using a 1K thermocouple to take the temp of the coolant for early switch over prevention; a second temp probe to control the vegtherm; and finally a timed purge.
I have just been going strictly from a gut feeling ... everything I have read seems to imply 2 minutes is more than enough time.Kuan wrote: 2 minutes for purge seems like a long time to do everytime you shut down... Have you actaully checked how long it takes to purge the wvo out of the engine or are you just going by gut feeling.
I spent most of my time looking at OBD-II because it is more standard ...Luna-Sea wrote: What info is available from the older OBD?
Ok, that totally makes sense - I was just thinking with the turbotimer its after you turn the car off.northriver wrote: I have just been switching back to diesel a few minutes before I get to where I am going.
I think it would be good to monitor actual WVO temperature before injection as this is the critical item that could go unnoticed indefinitely but actually cause problems in the long run.northriver wrote: For an initial version I am aiming for:
- Monitoring coolant temperature,
- Monitoring WVO filter pressure,
- Monitoring WVO fuel level,
- Controlling WVO valves and in-line heater
