Oil Pressure Check Light Not Working.
str8gooods
Vehicle: Mitsubishi Pajero 2.8l SWB
Post by str8gooods »
I noticed recently that my oil pressure check light no longer comes on with the ignition. I pulled the cluster out and swapped some bulbs around and the light is still out. It did come back on for one start cycle a couple days ago but has now seemed to have quit for good. My question is where is the signal sent from, so I can attempt to trace back and find the issue.
On a side note, while the cluster was out, I re-soldered all the visible contacts on the back of the cluster to try and fix my intermittent/bouncing tach that seems to plague many of the pajeros and delicas out there. It has not solved the problem. Where is the tach signal sent from as well.
Thanks in advance for your help.
.:FoRuM56:.
Re: Oil Pressure Check Light Not Working.
Post by .:FoRuM56:. »
The oil pressure sending unit is located under the oil filter on the pedestal mount assembly. It's just a single wire unit, so it's possible the connection broke right at the sensor...If required, a new sensor is like 5 bucks, but it is a very rare thread pitch. And by rare I mean 10mm 0.9...which is like a 27 1/4 npt.
str8gooods
thanks for the info, It came back on again today for a two starts. I recently did an oil change so its possible it was damaged. Ill take a look
Artie Fufkin
Vehicle: Pajero
Post by Artie Fufkin »
Had this happen a year or so ago. Turned out to be the sensor went. Yes, it was about $5.00
Told its a very common size in Japanese vehicles. The mechanic I took it to had no trouble at all getting it. Don't recall the number ..NP1 or something like that. Don't look for that number I know its wrong, just recall something along that line.
Obviously the most important thing is to confirm your oil pump is working. First double check your oil level. Second with engine running remove the oil cap and observe oil it being pumped up into valve cover. You can also pull out dip stick and it should splatter out a bit.
If its not doing the above DON'T DRIVE IT. If it is pumping but the oil light is not turning off its most likely the sensor in my experience and you should be ok to drive it to the store to get the appropriate part.
(I'm not a mechanic though so ultimately don't listen to me)
AF
str8gooods
The oil level is fine, And the pump is doing its job. My issue was the light was not coming on with the rest of the check lights on ignition. It has started working again, so my guess is the sensor is on the fritz. Where could I find this part. Is it a something that was also used on cars/trucks in available here North America?
Artie Fufkin
Vehicle: Pajero
str8gooods wrote:The oil level is fine, And the pump is doing its job. My issue was the light was not coming on with the rest of the check lights on ignition. It has started working again, so my guess is the sensor is on the fritz. Where could I find this part. Is it a something that was also used on cars/trucks in available here North America?
str8gooods,
Sorry, can't help you with part because someone else sourced it and have no idea where he got it.
I'm sure someone on here will come along and send you in the correct direction. Lots of helpful people on here.
AF
Profister
Post by Profister »
str8gooods, I can easily find the part number based on the chassis number if you want; just PM it to me. You can also install MMC ASA and DIY. :M
Profister
Post by Profister »
OK, in your case you can use the part shown below )which I have already posted in another thread) or any cross referenced one. I paid $18 for an aftermarket one in Lordco which I concider a ripoff. The genuine one should not cost more than $25.
str8gooods
I am assuming that a Mitsu dealership here would not have this? Should I just purchase online?
nxski
Post by nxski »
It looks like the part is for a Fuso so the dealer should carry it!?
Fuso is handled by Pacific Coast Heavy Truck on Annacis Island, I've only been there once and that was back in '08. Here is the phone number: Fuso ~ (604)-526 2231. They are open 07hrs to midnight on weekdays & 07hrs to 17hrs on the Saturday & Sunday. Not sure how much is going to cross reference but it's worth a try.
Rising Sun Auto Import
str8gooods wrote:I am assuming that a Mitsu dealership here would not have this? Should I just purchase online?
We have both Hyundai OEM and Mitsubishi OEM in stock.
Steven
Profister
Post by Profister »
I am sick and tired of these sales ads. Here is my Lordco one which I have posted before. DO NOT spend more than shown below on the switch .
PS. FUSO dealers did not have it when I needed it.
Profister wrote:I am sick and tired of these sales ads. Here is my Lordco one which I have posted before. DO NOT spend more than shown below on the switch .
OP has a hard time to source OEM part here and probably most people are curious about local availability.
We have two OEM parts and my post is definitely not a sales ad.
You can bring it for OP if you want.
The Lordco part you post is from China.
There are $5 switch and $55 switch in the market.
You will get what you paid for.
Be mature.
Steven :M
ps. I do not mean all Chinese parts are bad.
Of course there are some good quality parts there as their market is incredibly huge.
** ( another example ) Here's another 4m40 alternative starter relay made in China sold by Lordco at $40 something .
If you use it with modi ( lots of labour ), it may last a few days.
What a waste of money!
One more,
We have $40 ,$75 and $125 for L300 front brake pads in the market.
What a huge price difference!
Time for jesse's turn?
4M40 relay (2).JPG (84.55 KiB) Viewed 7886 times
Profister wrote:OK, in your case you can use the part shown below )which I have already posted in another thread) or any cross referenced one. I paid $18 for an aftermarket one in Lordco which I concider a ripoff. The genuine one should not cost more than $25.
Yes, original price from Mitsubishi Japan is currently 1,900yen ( appro.CAD $26 ).
We need to consider Japan National VAT, EMS Shipping to Canada, need someone who can handle for you.....
Steven 8-)
Return to “Pajero”
