Auber Digital Boost Gauge
murdermitten
Vehicle: 1990 P35W
Post by murdermitten »
Hi Everyone-
I have purchased an Auber digital boost gauge that I intend to install alongside my Auber EGT gauge:
Screen Shot 2018-03-27 at 1.46.36 PM.png (211.2 KiB) Viewed 6164 times
Sensor:
Screen Shot 2018-03-27 at 1.58.38 PM.png (310.59 KiB) Viewed 6164 times
I'm wanting to clear up a few things before I start wiring stuff up and get in over my head.
Based on previous threads, I'm going to splice into the vacuum line/pressure hose (or add a small section of new hose from the IP (any reason not to just cut the original pressure hose?) that runs directly over the engine valve cover.
I'll add a t-connector then use another small piece of hose to run to the Auber sensor shown below:
Screen Shot 2018-03-27 at 1.39.47 PM.png (85.58 KiB) Viewed 6164 times
Wiring the sensor itself will be pretty straightforward, it's just splicing and running the tubing that I want to make sure I get right the first time.
Weirdly it says the sensor only takes 5A? Is it that the digital gauge itself reduces the voltage (it is a 12V DC gauge)
Thanks guys,
Eric
204explorer
Vehicle: l400
Post by 204explorer »
I assume you mean 5V and not 5A. Automotive sensors commonly use 5 Volts. The gauge reduces the supply voltage to the sensor to 5 Volts.
I like these gauges. I gave 2 in my van and plan to add 2 more.
Sent from my SM-G950W using Tapatalk
murdermitten
Vehicle: 1990 P35W
Hi 204Explorer, thanks for the insight, I looked again and yes it says 5V, so no worries there!
You said you have 2 Auber gauges? Did you install this one? Curious what the ones you have are...I love them too!
Thanks,
Eric
204explorer
Vehicle: l400
I have two of the round ones. I like them a lot. I wish they would dim more at night. I attach a pic when i get to my van.
204explorer
Vehicle: l400
Here is what my setup looks like. The open spot is for a blue coolant temp gauge. You can see the alarm light and buzzer i wired to the gauges. Also from Auber.[img]https://uploads.tapatalk-cdn.com/201804 ... ed9a9f.jpg[/img][img]https://uploads.tapatalk-cdn.com/201804 ... 866d06.jpg[/img]
