L300 faulty Turbo
FredVenne
Vehicle: L300 Exceed Pop-Top, Pajero Exceed
L300 faulty Turbo
Post by FredVenne »
Good day!
Am I the only one in this community that has not just once but twice the turbo plug pop out from 2 different brand new turbos? Well the second one was 3 years old.
This is very annoying. Do you guys carry a 2nd turbo all the time with you guys?
Anyone?
-The Mighty Yeti
ChuckBlack
Vehicle: L300 Jasper
Re: L300 faulty Turbo
Post by ChuckBlack »
holy shit! I've never had this issues!
L300 Jasper, :-D
L300 Chamonix, :-)
Pajero Mini, :-(
Pajero GDI :o
Pajero DiD 8-)
The Mitsubishi turbos I've seen come with that plug welded in place:
I can't see any evidence of broken welds in your picture, so I'm presuming that's an aftermarket turbo. I'd weld a plug back in place rather than buy a whole new turbo. You might want to check your exhaust too, there might be excessive backpressure from a dented pipe or internally collapsed silencer.
FredVenne
Post by FredVenne »
Yes I will have a new plug inserted and welded on one of the 3 turbos I have at home. 2 brand new, had about 5000km on them. One has a pretty deep crack in the housing (not the turbine part) and the other one is leaking oil. At ranging between 400$ and 600$, you'd expect them to last longer than that.
So again, my question to you guys was, am I the only one to have such issues with turbos? Am I the only one that have to change them every couple of years?
-The Mighty Yeti
Not sure about everyone else, but my original turbo is 23 years old with 250,000km on it, and still has very little play in the bearings. I only replaced it because I was upgrading to a larger turbine and thought I might as well fit a new turbo at the same time. Turbo failure doesn't seem to be something people talk about a lot.
TieMyShoe
Vehicle: L300
Post by TieMyShoe »
whag are your egts? With that kind of failiure (cracked housings and such) i would be looking at how hot you are running..
FredVenne
Post by FredVenne »
Not sure how to check this.
-The Mighty Yeti
TieMyShoe
Vehicle: L300
Post by TieMyShoe »
you will need to install an EGT gauge/pyro
