Help!!!!!! Need parts.
- Vehicle: 92 Delica Exceed
Hey all,
Hope things are well for you. I, however, need some help.
I took my Deli into the shop for a small leak, which turns out was due to a blown head gasket. Ugh.
So, I am looking for a head gasket set, a timing belt and a water pump. Anyone know where I can get the parts?
Will be forever in your debt...and will pay for good info with a tasty bottle of rum :)
Thanks all. Look forward to hearing from you
Erik
Erik
- thedjjack
- Vehicle: 1989 L300 HITOP!!
Re: Help!!!!!! Need parts.
any of the dealers:
Rising Sun, Amazing Auto, Combs Country Auto, Maximum Overdrive.... come to mind.
Make sure you use a name brand gasket (also look at posts for cracked heads (very common))...
- Vehicle: 1995 l400 swb
Rocky Mountain , many dealers get parts from them,
http://www.rockymountainimports.net/jdm ... -L400.html
- Vehicle: 1992 Delica
Not sure where you're from but I live in Ontario. I've been using Rising Sun personally for all my needs. Even though they're on the other side of the country from me, they've supplied me with great parts and all kinds of great tech support and advice since first purchasing my van. In fact, there's some things in the mail from them on their way to me right now....
Good luck with everything:)
P.S., I drink vodka,,lol
Thanks for the info folks....ugh. this makes me sad. Poor old girl. Has anyone dealt with Amazing Auto Imports in Richmond? Good? Bad?
Thanks all
Thanks all
Mardys great to deal with , but if it's parts you want go straight to Rocky Mountain Imports, they are pretty much nothing but a parts outlet , even Mardy shops there
- Vehicle: delica
You can get the head gasket kit from any parts jobber. Mid-80s dodge ram pickups had the 4D56t engine as an option. Just ask for a gasket kit for that truck with the diesel engine and they should be able to get you rolling.
- Firesong
They aren't always the same. I bought parts on that premise and you can't return somethings once opened.
I ended up taking the old girl to Rising Sun in New West. Hoping for the best. Thanks for all the help :)
- Vehicle: delica
Depends on your jobber I guess, but I used that exact head gasket kit from Lordco, and the shop I usually use always lets me return parts that turn out incorrect. But if you order parts for that specific engine and model, it's the same block.Firesong wrote:They aren't always the same. I bought parts on that premise and you can't return somethings once opened.
