revs really high between shifts/delay on gas pedal release
- Member's Photo Album: http://picasaweb.google.ca/116007411398370170745/D
- Vehicle: 91 Delica
Recently my gas pedal seems to have a delay in the release. I push in the pedal and it takes a few extra seconds to get back to its original position. I tightened up the cable which didnt really help. Has anyone come across this problem/have a solution?
Re: revs really high between shifts/delay on gas pedal release
Did it just start happening when it got cold out ?
yup.
i was thinking it could be the housing contracting with the cold, but not sure
bad cable?
Try to rev the motor from the injector pump (I assume it is a diesel (it should not have a gas pedal
If the motor revs fine from the injector pump. bad throttle cable or needs lube or has water in it.
keep us posted
keep us posted
also cable needs some play
the problem is intermittent. when i rev it manuually it is fine. the cable releases slowly. probably build up/water in the housing.
how do you lube it?
take the cable out and run oil and graphite down it.
Personally I would replace it if you can get new. It is an important cable and maybe a sign of failure.
