Costs: -Jeep Bumper $315.00 with taxes (Trail Gear Canada (NSOR))
-Steel to tie Bumper into frame ~$25.00 metal supermart
-Friends 240 volt Mig Priceless (tacked the welds with my 120volt)
Photos:
Old setup (free stock bumper parts please PM):
New Bumper!:
Old bumper off:
Drilled square hole and punched through to frame so I could connect 2.5 inch square 1/4 tubing to the shackle mounts (not much frame on a unibody!)
Finished holes
7.5 inch 2.5 square tubing with 5.5 inches of top cut off to make a 2.5X2 inch tube pushed through behind shackles.
Put a tube between that connects to stock step mounts:
Used a Toyota mount for tire mount (Jeeps are 5 bolt) and License mount:
1/4 plots welded in some white Tremclad:
Had to offset bumper 1/4 inch and notch the door 1/4 inch to clear hinge:
Finished Project:
