Turbo Timer f'd up
shannon
Vehicle: Mitsubishi Pajero/Suzuki Carry
Turbo Timer f'd up
Post by shannon »
Hey,
I am having troubles with my turbo timer. Tried to reset it to zero. Paj still won't turn off. Runs for about 10 minutes. Removed turbo timer and still runs!!!! WTF Can anyone help me out.
Shannon
Re: Turbo Timer f'd up
This sounds like a job for Mararmeisto...
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
after you turn it off and it keeps running is there power to the fuel shut of solenoid?
If it still has power find out why? I would think it was related to the timer install.
PM sent.
shannon
Post by shannon »
Have a lead on a solenoid in Vancouver. Might head up to Malahat on Saturday and grab a used one if this doesn't pan out. Today it turned off, no problem, right away after a 25 min drive. Back home it ran for about 10 min then shut off. My only worry is if it doesn't turn off at all! What do you do then? Just run out of fuel? I have a road trip planned for next week :?
shannon wrote:My only worry is if it doesn't turn off at all! What do you do then? Just run out of fuel? I have a road trip planned for next week :?
Disconnect the battery. :?
thedjjack
Post by thedjjack »
pinch of the fuel line pre-injector pump?
remove the turbo timer :|
shannon
Post by shannon »
Turbo Timer is removed. Thanks for the tips. See how she runs today.
shannon
Post by shannon »
Drove around town and up to Parksville. Problem seems to have stopped. I usually run B100 but was out for a bit and ran two tanks of pump diesel. Back on B100, maybe this had something to do with it??
Nope. Just a coincidence
Return to “Pajero”
